MMC cant find partition
i’ve a Radxa Zero version 2GB with 8GB eMMC.
Did load the loader radxa-zero-erase-emmc.bin and flashed the board with Armbian v22.08.0, everything works good, the system loads, can reboot the board it load the system again - great.
Now, after 24h when booting the board it yields:
Model: Radxa Zero
SoC:   Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM:  2 GiB
MMC:   sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
unable to select a mode : -5
starting USB...
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-meson-u200
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
To make it work need to load the loader again and flash the emmc, then 24h same problem occurs.
Does anyone had same issue?
This is a known issue and is fixed in Armbian. However, you can see their image is still generated in 06/23, so it doesn’t contain this fix. In the mean time you can try manually flashing the bootloader according to this guide.
Thanks, that helped :slight_smile:
