Actually I fixed the first part of the problem ( that the internal analog sound was not being detected ). this was resolved by upgrading kernel from 5.15.76 to 5.15.80.
So now - the hardware, ie internal audio (not hdmi audio) is detected - and selected. And alsa mixer seems to work - and mpd is running… BUT - still no sound from attached speakers. If you have any tips or advice to make it play sound - they would be greatly appreciate…
[Sat Dec 03] root@batopi: ~$ amixer scontents
Simple mixer control 'Headphone',0
Capabilities: pvolume
Playback channels: Front Left - Front Right
Limits: Playback 0 - 3
Mono:
Front Left: Playback 3 [100%] [0.00dB]
Front Right: Playback 3 [100%] [0.00dB]
Simple mixer control 'Headphone Mixer',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 11
Front Left: 9 [82%] [-3.00dB]
Front Right: 9 [82%] [-3.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Playback Polarity',0
Capabilities: enum
Items: 'Normal' 'R Invert' 'L Invert' 'L + R Invert'
Item0: 'Normal'
Simple mixer control 'Capture Polarity',0
Capabilities: enum
Items: 'Normal' 'Invert'
Item0: 'Normal'
Simple mixer control 'ADC',0
Capabilities: cvolume cvolume-joined
Capture channels: Mono
Limits: Capture 0 - 192
Mono: Capture 192 [100%] [0.00dB]
Simple mixer control 'ADC Double Fs',0
Mono: Playback [off]
Simple mixer control 'ADC PGA Gain',0
Capabilities: volume volume-joined
Limits: 0 - 10
Mono: 9 [90%] [21.00dB]
Simple mixer control 'ADC Soft Ramp',0
Mono: Playback [on]
Simple mixer control 'ALC',0
Capabilities: cswitch cswitch-joined
Mono: Capture [off]
Simple mixer control 'ALC Capture Attack Time',0
Limits: 0 - 10
Mono: 7 [70%]
Simple mixer control 'ALC Capture Decay Time',0
Limits: 0 - 10
Mono: 7 [70%]
Simple mixer control 'ALC Capture Hold Time',0
Limits: 0 - 10
Mono: 7 [70%]
Simple mixer control 'ALC Capture Max',0
Limits: 0 - 28
Mono: 25 [89%] [31.00dB]
Simple mixer control 'ALC Capture Min',0
Limits: 0 - 28
Mono: 25 [89%] [25.50dB]
Simple mixer control 'ALC Capture Noise Gate',0
Simple mixer control 'ALC Capture Noise Gate Threshold',0
Limits: 0 - 31
Mono: 24 [77%]
Simple mixer control 'ALC Capture Noise Gate Type',0
Capabilities: enum
Items: 'Constant PGA Gain' 'Mute ADC Output'
Item0: 'Constant PGA Gain'
Simple mixer control 'ALC Capture Target',0
Limits: 0 - 10
Mono: 8 [80%] [-4.50dB]
Simple mixer control 'DAC',0
Limits: Playback 0 - 192
Mono:
Front Left: Playback 152 [79%] [-20.00dB]
Front Right: Playback 152 [79%] [-20.00dB]
Simple mixer control 'DAC Double Fs',0
Simple mixer control 'DAC Mono Mix',0
Simple mixer control 'DAC Notch Filter',0
Simple mixer control 'DAC Soft Ramp',0
Mono: Playback [on]
Simple mixer control 'DAC Soft Ramp Rate',0
Limits: 0 - 4
Mono: 3 [75%]
Simple mixer control 'DAC Source Mux',0
Capabilities: enum
Items: 'LDATA TO LDAC, RDATA TO RDAC' 'LDATA TO LDAC, LDATA TO RDAC' 'RDATA TO LDAC, RDATA TO RDAC' 'RDATA TO LDAC, LDATA TO RDAC'
Item0: 'LDATA TO LDAC, RDATA TO RDAC'
Simple mixer control 'DAC Stereo Enhancement',0
Limits: 0 - 7
Mono: 6 [86%]
Simple mixer control 'Differential Mux',0
Capabilities: enum
Items: 'lin1-rin1' 'lin2-rin2' 'lin1-rin1 with 20db Boost' 'lin2-rin2 with 20db Boost'
Item0: 'lin1-rin1'
Simple mixer control 'Digital Mic Mux',0
Capabilities: enum
Items: 'dmic disable' 'dmic data at high level' 'dmic data at low level'
Item0: 'dmic disable'
Simple mixer control 'Left Headphone Mixer LLIN',0
Simple mixer control 'Left Headphone Mixer Left DAC',0
Simple mixer control 'Left Headphone Mux',0
Capabilities: enum
Items: 'lin1-rin1' 'lin2-rin2' 'lin-rin with Boost' 'lin-rin with Boost and PGA'
Item0: 'lin1-rin1'
Simple mixer control 'Right Headphone Mixer RLIN',0
Simple mixer control 'Right Headphone Mixer Right DAC',0
Simple mixer control 'Right Headphone Mux',0
Capabilities: enum
Item0: 'lin1-rin1'
