Thank you Stephen.
I can use my 10.1 MIPI DSI display along with my Rock 5B now.
I am so happy.
Thanks Stephen for getting this going really appreciated. Can confirm all up and running under Ubuntu now.
Just as a note for anybody wanting to rotate the screen to landscape you can use the below command and of course add this to a start up script if needed.
$echo 3 | sudo tee /sys/class/graphics/fbcon/rotate_all
Cheers
and i suspect changing the number for other rotations right?
@hannes-campidell correct
0 - Normal rotation
1 - Rotate clockwise
2 - Rotate upside down
3 - Rotate counter-clockwise
Cheers
thankyou for the infos and does it also work to rotate it from xrandr or from the desktop and does it need a reboot
xrander isnāt installed by default so havenāt tested it or the Debian image yet. Primarily I would like to get Android running on it at this stage but in the mean time have some other testing to be done with some HATS before reloading OS.
Cheers
@Stephen Iām trying to use a BTT pitft50 display with rock5b. Is there any way to get this working?
The next thing to resolve is the touch screen function. How to set it properly on debian.
that should be easy becaus it is just i2c
I have a problem with how to calibrate the touch area.
When I want to touch the top-left area, I should touch the top-right area.
Could you please give me a solution?
just rotate the screen with this command:
echo 2 | sudo tee /sys/class/graphics/fbcon/rotate_all
and all problems should dissapear
It doesnāt work when I use Debian with desktop.
I was using Display Setting and change the rotation to the left or right to rotate the screen.
I am also having problem. Could not manage it to work. May be today I will try from scratch.
I donāt have the /sys/class/drm/card0-DSI-1 folder in the debian system
Ok it worked on ubuntu
I needed to fix apt repo for radxa as explained here
So, the screen lights up like it has power, but has no signal. When I cat modes in /sys/class/drm/card0-DSI-1, I get 800x1280. Currently running kernel 5.10.110-34 and extlinux.conf shows /dtbs/5.10.110-34-rockchip-gca15bbe36e6c/rockchip/overlay/rock-5b-radxa-display-10hd.dtbo. Not sure what to try next.
how to do this in armbian?
how to do this in android?
The next Android release will support the Radxa Display 10.
At last yesterday I managed it to work on armbian also
Hi @tsadigov,
thatās a great news ! I find that display very nice.
Would you be kind enough to share your knowledge on how to achieve this under Armbian.
