Minimizing images
Hey all,
a new member here, just got my Rock Pi S -boards. Looks great so far!
One thing I did notice about the current Debian image is that it does take quite a lot of space by default. This is especially a concern when using the eMMC model with fairly limited storage.
My first observation is that the locales are generated for quite a few languages. The /usr/share/locale directory takes up 46 MB of space by default:
rock@rockpis:~$ sudo du --max-depth=1 -hc /usr/share/locale | sort -h
12K     /usr/share/locale/am
12K     /usr/share/locale/anp
12K     /usr/share/locale/bo
12K     /usr/share/locale/br
12K     /usr/share/locale/brx
12K     /usr/share/locale/de_CH
12K     /usr/share/locale/en_CA
12K     /usr/share/locale/ilo
12K     /usr/share/locale/kw
12K     /usr/share/locale/kw@kkcor
12K     /usr/share/locale/kw@uccor
12K     /usr/share/locale/kw_GB
12K     /usr/share/locale/mai
12K     /usr/share/locale/mg
12K     /usr/share/locale/mn
12K     /usr/share/locale/my
12K     /usr/share/locale/nso
12K     /usr/share/locale/rw
12K     /usr/share/locale/tw
12K     /usr/share/locale/ug
12K     /usr/share/locale/ur
12K     /usr/share/locale/wba
12K     /usr/share/locale/wo
12K     /usr/share/locale/xh
12K     /usr/share/locale/yo
16K     /usr/share/locale/bal
16K     /usr/share/locale/fa
16K     /usr/share/locale/nds
16K     /usr/share/locale/tg
16K     /usr/share/locale/wa
16K     /usr/share/locale/zh_HK
16K     /usr/share/locale/zu
20K     /usr/share/locale/is
20K     /usr/share/locale/ka
20K     /usr/share/locale/mk
20K     /usr/share/locale/oc
24K     /usr/share/locale/si
24K     /usr/share/locale/sq
32K     /usr/share/locale/be@latin
32K     /usr/share/locale/bn
32K     /usr/share/locale/gd
32K     /usr/share/locale/ia
36K     /usr/share/locale/bs
36K     /usr/share/locale/en_GB
36K     /usr/share/locale/ku
40K     /usr/share/locale/sr@latin
44K     /usr/share/locale/cy
48K     /usr/share/locale/fur
48K     /usr/share/locale/he
52K     /usr/share/locale/af
56K     /usr/share/locale/ar
56K     /usr/share/locale/et_EE
56K     /usr/share/locale/lv
72K     /usr/share/locale/ky
108K    /usr/share/locale/be
108K    /usr/share/locale/tl
112K    /usr/share/locale/ms
112K    /usr/share/locale/nn
120K    /usr/share/locale/kk
140K    /usr/share/locale/gu
140K    /usr/share/locale/or
148K    /usr/share/locale/hi
148K    /usr/share/locale/pa
156K    /usr/share/locale/ast
160K    /usr/share/locale/as
160K    /usr/share/locale/ml
164K    /usr/share/locale/bn_IN
168K    /usr/share/locale/ne
168K    /usr/share/locale/te
172K    /usr/share/locale/kn
192K    /usr/share/locale/km
200K    /usr/share/locale/dz
216K    /usr/share/locale/ta
224K    /usr/share/locale/lg
232K    /usr/share/locale/lt
276K    /usr/share/locale/mr
332K    /usr/share/locale/th
380K    /usr/share/locale/eu
436K    /usr/share/locale/ro
456K    /usr/share/locale/ga
484K    /usr/share/locale/gl
536K    /usr/share/locale/en@boldquot
536K    /usr/share/locale/en@quot
548K    /usr/share/locale/et
560K    /usr/share/locale/ko
580K    /usr/share/locale/sk
648K    /usr/share/locale/fi
700K    /usr/share/locale/el
716K    /usr/share/locale/sl
720K    /usr/share/locale/bg
812K    /usr/share/locale/eo
856K    /usr/share/locale/hr
856K    /usr/share/locale/pt
880K    /usr/share/locale/zh_TW
948K    /usr/share/locale/id
1.1M    /usr/share/locale/sr
1.1M    /usr/share/locale/tr
1.2M    /usr/share/locale/da
1.2M    /usr/share/locale/hu
1.2M    /usr/share/locale/it
1.2M    /usr/share/locale/nl
1.3M    /usr/share/locale/nb
1.3M    /usr/share/locale/vi
1.4M    /usr/share/locale/ca
1.4M    /usr/share/locale/pt_BR
1.5M    /usr/share/locale/zh_CN
1.6M    /usr/share/locale/cs
1.6M    /usr/share/locale/es
1.7M    /usr/share/locale/de
1.7M    /usr/share/locale/pl
1.7M    /usr/share/locale/sv
1.8M    /usr/share/locale/ja
1.9M    /usr/share/locale/ru
2.0M    /usr/share/locale/fr
2.3M    /usr/share/locale/uk
46M     /usr/share/locale
46M     total
By reducing the language choices we could drop down the image size quite significantly.
Also documentation (/usr/share/doc, 24 MB) and man pages (/usr/share/man, 7.9 MB) are created by default in the current images, this would save additional 36 MB.
You can create a minimal Rockpi S image with GitHub - armbian/build: Armbian Linux build framework generates custom Debian or Ubuntu image for x86, aarch64, riscv64 & armhf or download a testing minimal image with Debian bullseye Radxa Rockpi S - Armbian
But if this is not enough, you have to make a completely custom Linux with Yocto or Buildroot … which will not be simple.
Hey @kipe. You can build your own custom image using this Yocto layer (https://github.com/nishantpoorswani/meta-radxa.git). It has 2 default image recipes i.e console and minimal. The Readme.md contains all the information to build the image. Also you can create your own custom image recipe to include the necessary packages as per your requirement and build with the meta-radxa. I hope you find this helpful.
