MCP2515 overlays for zero
I have MCP2515 connected to spiB port of zero
connections are follows
MCP2515 <==> Zero Header Pins
MISO -21
MOSI -19
SS - 24
INT - 18
SCLK - 23
I am have error in compiling overlay
/dts-v1/;
/plugin/;
compatible = “radxa,zero”, “amlogic,g12a”;
fragment@0 {
	target = <&spicc1>;
	__overlay__ {
		mcp2515_int_pin: mcp2515_int_pin {
			amlogic,pins = <&gpio 73>;
            amlogic,function = "irq";
            amlogic,pull = <0>;
fragment@1 {
	target-path = "/";
	__overlay__ {
		can_mcp2515_osc: can-mcp2515-osc {
			compatible = "fixed-clock";
			clock-frequency = <16000000>;
			#clock-cells = <0>;
fragment@2 {
	target = <&spicc1>;
	__overlay__ {
        pinctrl-0 = <&spicc1_pins &spicc1_ss0_pins>;
        pinctrl-names = "default";
        #address-cells = <1>;
        #size-cells = <0>;
        status = "okay";
        mcp2515: spidev@0 {
                compatible = "microchip,mcp2515";
                reg = <0>;
                interrupt-parent = <&gpio_intc>;
                interrupts = <60 2>;
                spi-max-frequency = <16000000>;
                clocks = <&can_mcp2515_osc>;
                pinctrl-0 = <&mcp2515_int_pin>;
What’s the error?
Is this right way to defining my hardware connection of mcp2515 to zero ?
No, not if it won’t compile. What error are you getting?
it compile without error but I am not able to check if kernel found it as can interface
Were you able to get this going? I have a board I designed. I’ve enabled the SPI and I’ve installed can-utils, but I’m not sure where to go from there.
I am at same stage
