I flashed the image from ROCK-5B-Android12-rkr10-20221103-spi-nvme-rkupdate.zip using RKDevTool 2.96. Flashing was fine but it wasn’t booting (just a rockchip logo on screen)
After that, I can not do anything wirh RKDevTool, just error and fails
MASKROM device is detected
Test device fail. Note: Communication issue, Certainly please check usb, Comle… (…make this fucking tool window resizable)
GetFlashId fail
Reset device fail
Booting debian vom NVME works only if a SD card is inserted.
Tried all combinations (Nothing installed, NVME, SD, NVME + SD and different USB cables) and was able to do the SPI Flash thing for booting dabian from NVME with SD card installed, no NVME. Still not sure what did the trick.
hi Zenox, did you fix that error by any chance. i am also stuck at the same point.
my Rock5b stopped working all of a sudden and never bootep up after that.
