Manjaro update freezes
I’ve installed Manjaro to the eMMC with the USB A to USB A method but when I run software update after install it always freezes. At first it was stopping the update process due to dropping the WIFI connection, so I hard-wired the Rock Pi 4 to my router and now the entire system is locking up during the update install process. I’ve tried this with two different Rock Pi’s with their own eMMC cards but I get the same result every time. What could be causing the issue?
I’m using the Manjaro 19.12 image.
You are doing something fundamentally wrong or generic / low quality software support? Mainline Linux, which is Manjaro based on, is not matured.
You may be running into this issue:
https://forum.manjaro.org/t/swap-never-used-rockpi-4/113176
There are some workarounds mentioned in that thread.
Manjaro devs have said they are looking into it:
