git clone https://github.com/happyme531/linux-vendor-RK3588-PKGBUILD
mv linux-vendor-RK3588-PKGBUILD linux
MAKEFLAGS="<your make flags>" sudo buildarmpkg -p linux
Note: On x86 machines the kernel build time is insane (~1.5hrs on high-end desktop cpu), please be patient. Building on an ARM machine is highly recommended if you have one.
the image will be built in /var/cache/manjaro-arm-tools/img/
Flash the image into an SD card using the tool you like (I recommend usbimager).
Prebuilt images
Coming soon
Current issues
Desktop environment not working
Serial console is hanging from time to time
GPU not working (apperantly)
Many features untested
Note
You need an u-boot in spi flash in order to boot this image. You can follow this guide to install it.
For some tf cards the u-boot is unable to boot automatically. This should be treated as a bug, but a current workaround to manually boot is executing these commands in the u-boot shell:
mmc list
run bootcmd
Don’t upgrade the “linux” package from the official manjaro arm repo!
To do that add this to /etc/pacman.conf as soon as possible
IgnorePkg = linux
Sometimes the boot partition is not mounted correctly. Manually mount it if you want to install new kernel.
I tried to build the kernel, but I’m getting this error message:
INSTALL /build/pkg/linux/boot/dtbs/rockchip/rk3588s-rock-5a.dtb
INSTALL /build/pkg/linux/boot/dtbs/rockchip/rk3588s-tablet-rk806-single-v10.dtb
INSTALL /build/pkg/linux/boot/dtbs/rockchip/rk3588s-tablet-v11.dtb
INSTALL /build/pkg/linux/boot/dtbs/rockchip/rk3588s-tablet-v10.dtb
/usr/sbin/ln: failed to create symbolic link '/build/pkg/linux/usr/lib/modules/5.10.66-5-3588testing+/extramodules': No such file or directory
==> ERROR: A failure occurred in package_linux().
Aborting...
-> Pruning and unmounting package cache...
==> no candidate packages found for pruning
-> Removing build files from rootfs...
==> Package linux failed to build, aborting
That is the PKGBUILD for the BSP kernel. Guess you could compile it on an ARM machine like this. Usually you would install it via an AUR helper on the machine itself like this, but that only makes sense if you can boot a kernel on the rk3588 in the first place
I’m not an expert, what does BSP means? if it is present in AUR I would think there is a way to use it . otherwise would be egg/chicken. I’m a bit surprised seeing manjaro made available before arch though
BSP means board support package. Hardware vendors usually ship a BSP with their board that also contains a patched Linux kernel. This kernel is not mainline, meaning not the official one from https://github.com/torvalds/linux
The PKGBUILD basically grabs this prebuilt BSP kernel from the Armbian website and strips the .deb files to get to the kernel. It than builds Arch packages from those files, which you can install with pacman.
Just do a
git clone https://aur.archlinux.org/linux-rockchip-rk3588-bin.git
cd linux-rockchip-rk3588-bin
makepkg --ignorearch
makepkg will then download the BSP kernel and build Arch packages from it. In the above description you should pass those packages, namely the kernel and the header files. Currently trying to get that to work
Thanks for the update. that’s what I thought looking at previous build commands.
I suppose --ignorearch is used to bypass architecture checks but then we have wrong cpu arch.
Won’t be of massive help here, as I’m not used to build kernels for foreign arch …
Looked a bit to archlinuxarm forums, but didn’t see much regarding that board
I wonder what the package mainteainer was able to do though.
I guess we’ll need to wait for more people having access to that board, or from radxha team maybe. I can imagine they have more priority issues to deal with such as improving graphics drivers support. I would rather have GPU acceleration available on linux than support for arch.
have you tried cross-compilation?
found that from archlinuxarm wiki:
This is the official cross-compiling method used at Arch Linux ARM. If you plan on building a lot of packages and want to speed up the process, the following guide will turn an x86 Linux computer into an ARM cross-compiler. It’s also much easier than most cross-compile setups.
not sure if relevant here but could be worth trying
well not sure I’ll be able to dedicate time for now as it will probably require efforts before making it work
might give a try when having more free time this week-end.
also from forums topic I post before, some one provided this build instruction:
Grab the ubuntu kernel, and replace the one in multi-platform tarball (make sure to remove the package with pacman), and you will have archlinux arm on your device.
