I’m using rockpi4b v1.4.
I install mainline u-boot at SPI flash, when booting debian in emmc, it reporting errors as follows:
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:4...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
598 bytes read in 30 ms (18.6 KiB/s)
select kernel
1: kernel-4.4.154-90-rockchip-ga14f6502e045
2: kernel-4.4.154-88-rockchip-00030-g90239a6
Enter choice: 1: kernel-4.4.154-90-rockchip-ga14f6502e045
Retrieving file: /vmlinuz-4.4.154-90-rockchip-ga14f6502e045
19427336 bytes read in 2020 ms (9.2 MiB/s)
append: earlyprintk console=ttyFIQ0,1500000n8 init=/sbin/init root=PARTUUID=b921b045-1d rw rootwait roo
tfstype=ext4
Retrieving file: /dtbs/4.4.154-90-rockchip-ga14f6502e045/rockchip/rk3399-evb.dtb
Skipping kernel-4.4.154-90-rockchip-ga14f6502e045 for failure retrieving fdt
Retrieving file: /vmlinuz-4.4.154-88-rockchip-00030-g90239a6
19427336 bytes read in 2022 ms (9.2 MiB/s)
tfstype=ext4
Retrieving file: /dtbs/4.4.154-88-rockchip-00030-g90239a6/rockchip/rk3399-evb.dtb
Skipping kernel-4.4.154-88-rockchip-00030-g90239a6 for failure retrieving fdt
SCRIPT FAILED: continuing...
MMC Device 1 not found
no mmc device at slot 1
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3c0000: USB EHCI 1.00
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found
Device 0: unknown device
ethernet@fe300000 Waiting for PHY auto negotiation to complete............user interrupt!
Could not initialize PHY ethernet@fe300000
But I can be workaround using wire to connect PIN 23 and 25 in https://wiki.radxa.com/Rockpi4/dev/spi-install
rock-pi-4-rk3399_defconfig and evb-rk3399_defconfig both have such bug.
I think that mainline u-boot seems to bave a bug seeking dtbs other than in emmc.
