i’m using a 4b+ and try to use the m2 extension board. How can i test, if my m2 extension board is working? I installed armbian 23.02.2 on the emmc and it’s working. I then attached the m2 extension board on the 4b+ and inserted a Kingston 120GB on it. After boot, i checked lsblk, but no nvme shows up. I put the m2 into an USB3 to M2 adapter and by using lsusb, i found a sda device. So the Kingston m2 module is working.
Is there a way to check, if the m2 extension board is working? Could it be, that the Kingston is not recognised by the extension board?
Any help is appreciated.
Kind rgards
