What is the benefit to have an extra Wifi module on the board when there is am onboard Wifi ?
Thank you
Thank you
If your wifi chip dies then having a way to plug one in makes you able to keep using the board. You could also be connected to two Wi-Fi networks at the same time to act as a wifi hotspot and forward traffic from your local private Wi-Fi network to a public Wi-Fi network.
I think that the m.2 slot for wifi cards is typically an m.2 E key though and the m.2 slot on the 5T is a B key. B key would be used for devices to connect to a cellular phone network which is different from wifi. The device also has a SIM card slot, which is something you need for identifying the device to a mobile phone network so I’m pretty sure that the purpose of the b key slot is to have a place to plug the mobile phone adapter so you can use it as an Android phone, not for a second wifi.
