Tap into Radxa’s apt and install rockchip-overlay. Then you can upgrade to Gen 2 speed by enabling the pcie-gen2 overlay in /boot/ hw_intfc.conf.
HTH
HTH
I have installed OMV on the Radxa Debian Stretch Arm64 base build.
Have a 4 port sata card running so expecting nvme to work.
So here is an updated omv-4.4-arm64.img.xz image
https://1drv.ms/u/s!AocmAh35i26QiR-EAvY_MCIaT_eV
Definitely edit /boot/hw_intfc.conf as gen 2.0 makes a big difference in performance and then just reboot
But just have a glance at
https://wiki.radxa.com/Rockpi4/Linux_system_runs_on_M.2_NVME_SSD
sudo apt-get install iozone3
cd to the mounted drive
iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
The small 4k random read/writes are very important the big packet burst transfers will return the big numbers but often its the small packets that will give the ‘feel’ of user performance.
Similar issue here I think:
HP SSD EX900 works with u-boot from Radxa image, but does not work with other distro images.
Could you please share what was the problem and link to resolution in github
Thank you
