Hi!
My goal is to build a system image for Cubie A5E from source to integrate e.g. a different DSI display. I started to build a system image as describe here: https://docs.radxa.com/en/cubie/a5e/low-level-dev/build. The build succeeded and I was able to write it to a SD-Card. But the system was not booting. I had not output from the serial console.
My next step was to test the board, cables and hdmi display (Full HD). I took one of the downloadable images (a527_linux_cubie_a5e_uart0_beta_20250211.img) and it worked. I got output from the serial console and later on the HDMI display. Everything was working.
Then I tried to build the system image as described here: https://linux-sunxi.org/Radxa_Cubie_A5E. The build succeeded and I was able to write it to a SD-Card. The system was able to boot and I got output on the serial console. The systems starts up to the login prompt but the HDMI display stayed dark - no output.
Has anyone an idea what went wrong?
Attached the startup log.
RadxaBuild3_StartUp_01.zip (41.2 KB)
