After installing ubuntu-desktop and switching to gdm3, I lost a lot of my icons. After uninstalling and switching back to lightdm, still having issues.
Also, the armbian-config shortcut no longer works
I can open it from the terminal but still, makes me think something else is broken I haven’t found yet.
Any ideas?
Newest issue, no hardware found under hardware in armbian-config
DTC somehow got wiped. It is fixed now.
Icons are also back, however armbian-config still has issues. I can open it from terminal, but not it’s shortcut.
Fixed. Followed same procedures I have before. Copied files from fresh install over to current install. Originally I had checked the fresh install at /usr/share/icons/ and found no dir called armbian, this time it was there.
