Linux-sky1 image Iso?
Would it be possible someone to provide an image ISO download of linux-sky1?
You can use sky1-linux-image-build to create an IMG or ISO file. If you follow the key points in this guide, you should end up with a bootable image.
From my experience, there are a few common pitfalls:
  • Kernel updates can sometimes result in an unbootable system.
  • Server Provisioning Guide
    • On the first boot, make sure to select the correct boot entry for your hardware.
    • In my case, that’s “O6N”.
    • Change the default boot entry before running apt upgrade!
    • You’ll also need to set up time synchronization manually — for example, using systemd-timesyncd.
Time sync
see archlinux wiki - systemd-timesyncd
#check time and date
date
timedatectl status
# set time manually
sudo date --set="2026-03-01 15:30:00"
# perform update - make sure you changed default boot order if your are not on O6 :) !
sudo apt update
sudo apt upgrade
# configure systemd-timesyncd
sudo apt install systemd-timesyncd
sudo nano /etc/systemd/timesyncd.conf
sudo systemctl start systemd-timesyncd
sudo systemctl enable systemd-timesyncd
sudo timedatectl set-ntp 1
Standard grub bootentry
after update - otherwise grub.cfg is blank
sudo grep menuentry /boot/efi/GRUB/grub.cfg
sudo grub-set-default 1 #in my case
sudo less /boot/efi/GRUB/grub.cfg #check Kernel parameters
Greetings!
Has anyone been able to get a working desktop environment with Sky1 Linux? I’ve tried ““./scripts/build.sh xfce desktop image” a whole bunch of times on my Orion O6 and have never been able to get a working graphical boot. Either it goes through the boot normally and then displays a solid grey screen and stays there forever, or with some attempts the bootloader doesn’t even find the kernel, complaining about a UUID that doesn’t exist.
Here are some ISOsthat I built with the image build program. Let me know if you need a different config!
Thank you! I tried the KDE ISO but unfortunately wasn’t able to get it to work. With the BIOS (1.1.0-1) set to ACPI, it loads the kernel but doesn’t seem to hand over to userspace. With the BIOS set to device tree, it doesn’t boot at all.
Hmm okay. I’m just uploading direct from the tool output so if there’s issues it’s unfortunately something above my head. I will upload a few more in case it was a glitch… otherwise we have to wait for the dev to push updates.
nope not so far, tried all methods and had no luck wit gui.
ik_llama @ cli works great for me atm :slight_smile:
Maybe there are upstream issues with the program because I can no longer get the image maker program to work properly. Weird!
