In Linux, Armbian, with gpioset command I can set only these pins:
/dev/gpiochip0 15
/dev/gpiochip0 16
/dev/gpiochip0 17
/dev/gpiochip2 10
/dev/gpiochip2 16
/dev/gpiochip2 4
/dev/gpiochip2 5
/dev/gpiochip2 7
/dev/gpiochip2 8
/dev/gpiochip2 9
How to activate others to work as normal GPIO?
Is there any tool to change function of PINs from command line?
root@rockpi1:~# which gpioset gpioget
/usr/bin/gpioset
/usr/bin/gpioget
root@rockpi1:~# cat /etc/issue
Armbian 22.08.0-trunk Bullseye \l
root@rockpi1:~# dpkg -l | grep gpio | cut -b1-40
ii gpiod 1.6.2
ii libgpiod2:arm64 1.6.2
Pins marked with “/dev/gpio…” are working OK.
Others don’t.
Here are graphics:
igorp
October 25, 2022, 8:29am
3
leszekrabka:
Thanks for support.
Here we go:
hastebin
You need to show this to right people. I am not the one.
Thanks for support.
Here we go:
I will try new images also.
New images didn’t help…
Installed image:
Armbian_22.08.7_Rockpi-s_bullseye_edge_5.19.16.img.xz
downloaded from
https://www.armbian.com/rockpi-s/
https://redirect.armbian.com/rockpi-s/Bullseye_edge
apt-get update
apt-get full-upgrade
apt-get install gpiod
Connected leds and run:
while true; do for val in 0 1; do killall gpioset; for chip in $(seq 0 4); do for pin in $(seq 0 31); do gpioset -b -msignal $chip $pin=$val; echo $chip $pin $val; sleep .01; done; done; done; done
to test all pins.
And for example pin GPIO1_C7 never blinks,
GPIO1_C6 never blinks,
GPIO1_D0 never blinks…
i got blank result when i used this
$ sudo gpioinfo
gpioget gpiochip1 23
gpioget: error reading GPIO values: No such file or directory
