Finally, my media center moved from raspberries to rockpi4. Everything was simple there, there was osmc. This is just Linux with the Kodi Media Center. LibreELEC is a cropped piece of shit.
Used the version from balbes-150 on 20200319. Many thanks to him for his work. Installed docker addon. Then he launched the containers home assistant and transmission
docker run -d --name=homeassistant -v /storage/usr/share/hassio/homeassistant:/config -v /storage/usr/share/hassio/share:/share -v /etc/localtime:/etc/localtime:ro --network host --restart=unless-stopped homeassistant/aarch64-homeassistant:latest
docker run -d --name=transmission -e PUID=1000 -e PGID=1000 -e TZ=Europe/Moscow -e USER=user -e PASS=pass -p 9091:9091 -p 51413:51413 -p 51413:51413/udp -v /media/dataSSD/transmission/config:/config -v /media/dataSSD/transmission/downloads:/downloads -v /media/dataSSD/transmission/watch:/watch --restart unless-stopped linuxserver/transmission
For YouTube Add-on tuned api, оIt turns out without this api the addon stopped working even on raspberries.
hassio-supervisor did not want to work here … well, uh well, and without it you can;)
