I’m trying to port an existing application from RPI to the RockPI s.
This is a node.js application. It’s running fine on the rockPi except for the following:
I installed libmraa. So when i do:
sudo mraa-gpio get 16
I get : Pin 16 = 0
Or : Pin 16 = 1 when button is pressed.
So this is already something. However, I’ve been struggling to make this work without sudo.
The NPM package mraa is unusable since it’s not updated and requires a very old version of node.
So i should be able to change / poll GPIO’s in CLI without sudo, to use GPIO on the rockPi.
First, create a group and add the user that needs access to the GPIOs to it (this is for the current user;
replace $USER with an explicit username if you want).
sudo groupadd gpio
sudo usermod -a -G gpio $USER
Now reboot
Second, add the following lines to /etc/rc.local (you will have to edit it as root, using sudo vi or whatever).
chown -R root:gpio /sys/class/gpio
chmod -R ug+rw /sys/class/gpio
Third, create a new udev rule in a file, say /etc/udev/rules.d/80-gpio-noroot.rules (you will have to edit it as root again):
# /etc/udev/rules.d/80-gpio-noroot.rules
# Corrects sys GPIO permissions on the Joule so non-root users in the gpio group can manipulate bits
# Change group to gpio
SUBSYSTEM=="gpio", PROGRAM="/bin/sh -c '/bin/chown -R root:gpio /sys/devices/platform/INT34D1:*/gpio'"
# Change user permissions to ensure user and group have read/write permissions
SUBSYSTEM=="gpio", PROGRAM="/bin/sh -c '/bin/chmod -R ug+rw /sys/devices/platform/INT34D1:*/gpio'"
Fourth, reboot or restart udev using
sudo udevadm trigger --subsystem-match=gpio
And finally test:
mraa-gpio get 16
The first call will not do anything but set up the GPIO, so the value will be -1, but following calls should work. And return a value between 0-1.
I have the same problem. I tried the solution but it does not work for my system: ROCK 4 SE + Debian Bullseye because /sys/devices/platform is different (no INT34D1), I have /sys/devices/platform/pinctrl/gpio with gpio71 and gpiochip032/64/96/128folders. So tried using pinctrl instead of INT34D1, but this did not work…
The solution above is OK for C program examples but it does not work for C++ examples. I need to access C++ code from my C++ application, but the linker fails if I link C code that does not have ‘main’.
All very frustrating…
OK now I have mraa working without sudo with C++ code…
1)
change the /etc/udev/rules.d/50-gpio.rules file in the tutorial above to:
SUBSYSTEM==“gpio*”, PROGRAM="/bin/sh -c ’
chown -R root:gpiouser /sys/class/gpio && chmod -R 770 /sys/class/gpio;
chown -R root:gpiouser /sys/devices/virtual/gpio && chmod -R 770 /sys/devices/platform/pinctrl/gpio;
chown -R root:gpiouser /sys$devpath && chmod -R 770 /sys$devpath
2)
Now you have to perform a system mraa-gpio get TWICE for all the pins you are using. If you don’t do that then the program will not run.
Presumably because the initialization code in the examples does not completely initialize completely.
What makes you think that the solution is not applicable to C++? Which solution exactly are you referring to?
And why does linking C code to your C++ application fail? Which command line do you use to link and which error message do you get?
