Libmraa frequency counter with GPIO
Hi all,
I am trying to read a square wave with the GPIO pins on rockpi4b, as with pigpio on a raspberry pi3b. However, the libmraa examples in C only show output generation but not input.
Would anyone please point me to an example as the following? Thank you very much!
#include <stdio.h>
#include <stdlib.h>
#include <stdarg.h>
#include <unistd.h>
#include <pigpio.h>
#define MAX_GPIOS 32
#define OPT_P_MIN 1
#define OPT_P_MAX 1000
#define OPT_P_DEF 20
#define OPT_R_MIN 1
#define OPT_R_MAX 300
#define OPT_R_DEF 10
#define OPT_S_MIN 1
#define OPT_S_MAX 10
#define OPT_S_DEF 5
typedef struct
   uint32_t first_tick;
   uint32_t last_tick;
   uint32_t pulse_count;
} gpioData_t;
static volatile gpioData_t g_gpio_data[MAX_GPIOS];
static volatile gpioData_t l_gpio_data[MAX_GPIOS];
static volatile int g_reset_counts[MAX_GPIOS];
static uint32_t g_mask;
static int g_num_gpios;
static int g_gpio[MAX_GPIOS];
static int g_opt_p = OPT_P_DEF;
static int g_opt_r = OPT_R_DEF;
static int g_opt_s = OPT_S_DEF;
static int g_opt_t = 0;
void usage()
   fprintf
   (stderr,
      "\n" \
      "Usage: sudo ./freq_count_1 gpio ... [OPTION] ...\n" \
      "   -p value, sets pulses every p micros, %d-%d, TESTING only\n" \
      "   -r value, sets refresh period in deciseconds, %d-%d, default %d\n" \
      "   -s value, sets sampling rate in micros, %d-%d, default %d\n" \
      "\nEXAMPLE\n" \
      "sudo ./freq_count_1 4 7 -r2 -s2\n" \
      "Monitor gpios 4 and 7.  Refresh every 0.2 seconds.  Sample rate 2 micros.\n" \
      "\n",
      OPT_P_MIN, OPT_P_MAX,
      OPT_R_MIN, OPT_R_MAX, OPT_R_DEF,
      OPT_S_MIN, OPT_S_MAX, OPT_S_DEF
void fatal(int show_usage, char *fmt, ...)
   char buf[128];
   va_list ap;
   va_start(ap, fmt);
   vsnprintf(buf, sizeof(buf), fmt, ap);
   va_end(ap);
   fprintf(stderr, "%s\n", buf);
   if (show_usage) usage();
   fflush(stderr);
   exit(EXIT_FAILURE);
static int initOpts(int argc, char *argv[])
   int i, opt;
   while ((opt = getopt(argc, argv, "p:r:s:")) != -1)
      i = -1;
      switch (opt)
         case 'p':
            i = atoi(optarg);
            if ((i >= OPT_P_MIN) && (i <= OPT_P_MAX))
               g_opt_p = i;
            else fatal(1, "invalid -p option (%d)", i);
            g_opt_t = 1;
            break;
         case 'r':
            i = atoi(optarg);
            if ((i >= OPT_R_MIN) && (i <= OPT_R_MAX))
               g_opt_r = i;
            else fatal(1, "invalid -r option (%d)", i);
            break;
         case 's':
            i = atoi(optarg);
            if ((i >= OPT_S_MIN) && (i <= OPT_S_MAX))
               g_opt_s = i;
            else fatal(1, "invalid -s option (%d)", i);
            break;
        default: /* '?' */
           usage();
           exit(-1);
   return optind;
void edges(int gpio, int level, uint32_t tick)
   l_gpio_data[gpio].last_tick = tick;
   if (level == 1) l_gpio_data[gpio].pulse_count++;
   if (g_reset_counts[gpio])
      g_reset_counts[gpio] = 0;
      l_gpio_data[gpio].first_tick = tick;
      l_gpio_data[gpio].pulse_count = 0;
int main(int argc, char *argv[])
   int i, rest, g, wave_id, mode, diff, tally;
   gpioPulse_t pulse[2];
   //int count[MAX_GPIOS];
   /* command line parameters */
   rest = initOpts(argc, argv);
   /* get the gpios to monitor */
   g_num_gpios = 0;
   for (i=rest; i<argc; i++)
      g = atoi(argv[i]);
      if ((g>=0) && (g<32))
         g_gpio[g_num_gpios++] = g;
         g_mask |= (1<<g);
      else fatal(1, "%d is not a valid g_gpio number\n", g);
if (!g_num_gpios) fatal(1, "At least one gpio must be specified");
   printf("Monitoring gpios");
   for (i=0; i<g_num_gpios; i++) printf(" %d", g_gpio[i]);
   printf("\nSample rate %d micros, refresh rate %d deciseconds\n",
      g_opt_s, g_opt_r);
   gpioCfgClock(g_opt_s, 1, 1);
   if (gpioInitialise()<0) return 1;
   gpioWaveClear();
   pulse[0].gpioOn  = g_mask;
   pulse[0].gpioOff = 0;
   pulse[0].usDelay = g_opt_p;
   pulse[1].gpioOn  = 0;
   pulse[1].gpioOff = g_mask;
   pulse[1].usDelay = g_opt_p;
   gpioWaveAddGeneric(2, pulse);
   wave_id = gpioWaveCreate();
   /* monitor g_gpio level changes */
   for (i=0; i<g_num_gpios; i++) gpioSetAlertFunc(g_gpio[i], edges);
   mode = PI_INPUT;
   if (g_opt_t)
      gpioWaveTxSend(wave_id, PI_WAVE_MODE_REPEAT);
      mode = PI_OUTPUT;
   for (i=0; i<g_num_gpios; i++) gpioSetMode(g_gpio[i], mode);
   while (1)
      gpioDelay(g_opt_r * 100000);
         g = g_gpio[i];
         g_gpio_data[g] = l_gpio_data[g];
         diff = g_gpio_data[g].last_tick - g_gpio_data[g].first_tick;
         tally = g_gpio_data[g].pulse_count;
         if (diff == 0) diff = 1;
         g_reset_counts[g] = 1;
         printf("g=%d %.0f (%d/%d)\n",
         g, 1000000.0 * tally / diff, tally, diff);
   gpioTerminate();
All the api can be found on Intel’s website:
mraa: api/mraa/gpio.h File Reference
Examples of C:
mraa/examples/c at master · eclipse/mraa · GitHub
