The red led located near the green power led on my Rock Pi 4B is flashing in double bursts. First noticed it while attempting to boot Armbian, so I shutdown.
Noticed it again before shutting down Debian, last night. Today, it is flashing before bootup, but only if the 64-bit Debian uSD is inserted. It didn’t happen with the 32-bit Debian boot uSD, so I flashed that uSD w/recent 64-bit Debian build. Now, the led flashes with that uSD too. Apart from that, everything else behaves normally. Is this just its little heartbeat?
I haven’t seen any documentation on error codes.
I’d forgotten and it just came back to me.
Thanks for the info.
BTW, thought you might find this interesting:
The Raspberry Pi 4 has landed! A sneak peak prototype review.
Two things that irritate me: Why is a chip labeled mirror-inverted?
Why is the old GPIO connector in through-hole technology and the new one in surface-mounting technology? From the front, the additional connector also looks a bit strange.
If you think that’s bad, you should read some of the comments
