Hi. I’m using X4 for some time with Home Assistant on it and it’s really working great! For the moment I’m using Wi-Fi as a means for network. I want to switch to LAN though, with PoE as a power. Yesterday I tried that but connecting it made connection very unstable: it constantly was switching up and down:
2024-11-21 17:15:33.796 homeassistant kernel: igc 0000:02:00.0 enp2s0: NIC Link is Down
2024-11-21 17:15:37.458 homeassistant kernel: igc 0000:02:00.0 enp2s0: NIC Link is Up 2500 Mbps Full Duplex, Flow Control: RX/TX
2024-11-21 17:15:37.460 homeassistant NetworkManager[415]: <info> [1732209337.4595] device (enp2s0): carrier: link connected
2024-11-21 17:15:45.759 homeassistant kernel: igc 0000:02:00.0 enp2s0: NIC Link is Down
2024-11-21 17:15:49.427 homeassistant kernel: igc 0000:02:00.0 enp2s0: NIC Link is Up 2500 Mbps Full Duplex, Flow Control: RX/TX
2024-11-21 17:15:49.429 homeassistant NetworkManager[415]: <info> [1732209349.4284] device (enp2s0): carrier: link connected
2024-11-21 17:15:49.867 homeassistant kernel: igc 0000:02:00.0 enp2s0: NIC Link is Down
There was also few instances of:
2024-11-21 18:52:21.926 homeassistant NetworkManager[416]: <info> [1732215141.9263] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
2024-11-21 18:52:21.946 homeassistant systemd[1]: Starting Network Manager Script Dispatcher Service...
2024-11-21 18:52:21.957 homeassistant systemd[1]: Started Network Manager Script Dispatcher Service.
2024-11-21 18:52:21.958 homeassistant NetworkManager[416]: <info> [1732215141.9585] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
2024-11-21 18:52:21.958 homeassistant NetworkManager[416]: <info> [1732215141.9588] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
2024-11-21 18:52:21.959 homeassistant NetworkManager[416]: <info> [1732215141.9596] device (enp2s0): Activation: successful, device activated.
I’m waiting for new cable (to eliminate it as a culprit) to test X4 booted from Manjaro Live USB with PoE and without it, but I thought I’m gonna ask anyway because maybe that’s known issue of the device or I255 chip…or something.
Power works properly, no interrupts there.
