I installed ubuntu and use with wifi hotspot. The problem is that despite having a 1 Gb connection, the maximum speed with the lan is 80 mb in download and 120 in upload. And as a hotspot it only bounces 30 mb in download . Usually the pc cable, always with Ubuntu, goes to 900 mb in download and 200 in up.Drivers failed?
Is there no one left?
Your question is too generic.
Generic answer:
Ethernet speed depends on various factors (kernel in use, cable CAT, router, wifi router, etc..) and can also be optimized (with some kernel params, IRQ affinity, etc…), search for the threads talking about measuring Gb ethernet speed. The tool you use to measure it must be the same for others in order to compare with.
With such a low speed I can assume (I might be wrong) you use Samba. Regarding Samba speed, seems to be compatible with what the samba users claim.
Regarding Wifi speed (and hotspot), things get worse. I should not get into this but here we go, for all the boards I have here with Cypress/Broadcom, the performance is poor to bad. Surprisingly, I have Realtek in my RockPi E (dev version) which performs great, a perfect match with my TPLINK router and ASKEY router.
Some reference:
Thanks for the explanations. I did the tests with the usual operating system, Ubuntu and Speedtest of Ookla. Usual cable, connected to the router, a Fritzbox 7590 with FTTH at 1 Gb. Speed I get with the pc, 900 Mb in down and 200 in Up, while with the Rockpi I have 80 in down and 120 in UP. And if I connect in Wi-Fi to the hotspot created with the Rockpi, then there really is something to cry. I will try to install the Win10, to see if it is really a hardware limitation, or just the driver not working under Ubuntu. Thank you
In your real case usage and test, you added internet latency, traffic shape, browser cache, and many variable factors.
Here are some of my tests (simple benchmarks) just for reference:
Gb Raw speed with iperf3 with Radxa X 2GB/4GB USB stick with ubuntu 20.04.3 kernel 5.12.2 (CLI) and my ancient Intel® Core™2 Duo CPU E8600@ 3.33GHz (LXDE desktop)
[ 5] local 192.168.254.72 port 46332 connected to 192.168.254.253 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 115 MBytes 965 Mbits/sec 0 1.58 MBytes
[ 5] 1.00-2.00 sec 112 MBytes 943 Mbits/sec 0 1.63 MBytes
[ 5] 2.00-3.00 sec 111 MBytes 934 Mbits/sec 0 1.82 MBytes
[ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 3.14 MBytes
[ 5] 4.00-5.00 sec 111 MBytes 933 Mbits/sec 0 3.14 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 3.14 MBytes
[ 5] 6.00-7.00 sec 112 MBytes 943 Mbits/sec 0 3.14 MBytes
[ 5] 7.00-8.00 sec 111 MBytes 933 Mbits/sec 0 3.14 MBytes
[ 5] 8.00-9.00 sec 112 MBytes 944 Mbits/sec 0 3.14 MBytes
[ 5] 9.00-10.00 sec 112 MBytes 943 Mbits/sec 0 3.14 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 943 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec receiver
iperf Done.
Connecting to host 192.168.254.253, port 5201
Reverse mode, remote host 192.168.254.253 is sending
[ 5] local 192.168.254.72 port 46336 connected to 192.168.254.253 port 5201
[ 5] 0.00-1.00 sec 112 MBytes 942 Mbits/sec
[ 5] 1.00-2.00 sec 112 MBytes 941 Mbits/sec
[ 5] 2.00-3.00 sec 112 MBytes 941 Mbits/sec
[ 5] 3.00-4.00 sec 112 MBytes 941 Mbits/sec
[ 5] 4.00-5.00 sec 112 MBytes 942 Mbits/sec
[ 5] 5.00-6.00 sec 112 MBytes 941 Mbits/sec
[ 5] 6.00-7.00 sec 112 MBytes 941 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 942 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 941 Mbits/sec
[ 5] 9.00-10.00 sec 112 MBytes 941 Mbits/sec
[ 5] 0.00-10.00 sec 1.10 GBytes 941 Mbits/sec receiver
iperf Done.
Real world wget download speed (I use CLI and not Desktop)
Radxa X Wifi 5GHz (2.5 mts from wifi router)
wlan0 IEEE 802.11 ESSID:"FIBER-5G"
Mode:Managed Frequency:5.5 GHz Access Point: 94:EA:EA:AA:87:8F
Bit Rate=6 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=63/70 Signal level=-47 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
alex@svn:/tmp$ ssh [email protected]
The authenticity of host '192.168.254.73 (192.168.254.73)' can't be established.
ECDSA key fingerprint is SHA256:Tp+y8ICknLJCCazPUPJ/BkLk4qO7BI4hqDGBwfZFNrM.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '192.168.254.73' (ECDSA) to the list of known hosts.
[email protected]'s password:
Welcome to Ubuntu 20.04.3 LTS (GNU/Linux 5.12.2-rockpix x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
Last login: Fri Feb 4 20:11:59 2022 from 192.168.254.253
ubuntu@rockpix:~$ wget https://speed.hetzner.de/100MB.bin
--2022-02-04 20:20:03-- https://speed.hetzner.de/100MB.bin
Resolving speed.hetzner.de (speed.hetzner.de)... 88.198.248.254, 2a01:4f8:0:59ed::2
Connecting to speed.hetzner.de (speed.hetzner.de)|88.198.248.254|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: ‘100MB.bin’
100MB.bin 100%[===================>] 100.00M 5.22MB/s in 22s
2022-02-04 20:20:27 (4.53 MB/s) - ‘100MB.bin’ saved [104857600/104857600]
ubuntu@rockpix:~$ ifconfig
enp1s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet6 fe80::2e0:4cff:fe88:67f prefixlen 64 scopeid 0x20<link>
ether 00:e0:4c:88:06:7f txqueuelen 1000 (Ethernet)
RX packets 2778637 bytes 2972404878 (2.9 GB)
RX errors 0 dropped 22 overruns 0 frame 0
TX packets 2091789 bytes 2607428298 (2.6 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 122 bytes 11582 (11.5 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 122 bytes 11582 (11.5 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.254.73 netmask 255.255.0.0 broadcast 192.168.255.255
ether 10:2c:6b:50:66:e0 txqueuelen 1000 (Ethernet)
RX packets 73217 bytes 108877105 (108.8 MB)
RX errors 0 dropped 2 overruns 0 frame 0
TX packets 17323 bytes 1631366 (1.6 MB)
Radxa X Gb eth
--2022-02-04 20:13:56-- https://speed.hetzner.de/100MB.bin
Resolving speed.hetzner.de (speed.hetzner.de)... 2a01:4f8:0:59ed::2, 88.198.248.254
Connecting to speed.hetzner.de (speed.hetzner.de)|2a01:4f8:0:59ed::2|:443... connected.
100MB.bin 100%[===================>] 100.00M 7.60MB/s in 15s
PC Intel E8600 box Gb eth
alex@svn:/tmp$ wget https://speed.hetzner.de/100MB.bin
--2022-02-04 17:13:14-- https://speed.hetzner.de/100MB.bin
100MB.bin 100%[===================>] 100,00M 7,64MB/s in 15s
2022-02-04 17:13:30 (6,71 MB/s) - ‘100MB.bin’ saved [104857600/104857600]
Testing with 1GB.bin data
ubuntu@rockpix:~$ df -lh
Filesystem Size Used Avail Use% Mounted on
udev 953M 0 953M 0% /dev
tmpfs 192M 3.9M 188M 2% /run
/dev/sda2 3.2G 2.2G 889M 71% /
tmpfs 959M 0 959M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 959M 0 959M 0% /sys/fs/cgroup
/dev/sda1 511M 36M 476M 7% /boot/efi
tmpfs 192M 0 192M 0% /run/user/1000
Don’t have enough space but I tried anyway:
Radxa X wifi 5G
Last login: Fri Feb 4 20:49:38 2022
ubuntu@rockpix:~$ wget https://speed.hetzner.de/1GB.bin
--2022-02-04 20:50:48-- https://speed.hetzner.de/1GB.bin
Length: 1048576000 (1000M) [application/octet-stream]
Saving to: ‘1GB.bin’
1GB.bin 88%[================> ] 888.19M 6.07MB/s in 2m 39s
Cannot write to ‘1GB.bin’ (Success).
ubuntu@rockpix:~$ rm *.bin
ubuntu@rockpix:~$ exit
logout
Connection to 192.168.254.73 closed.
Radxa X Gb eth
Last login: Fri Feb 4 20:50:46 2022 from 192.168.254.253
--2022-02-04 20:55:13-- https://speed.hetzner.de/1GB.bin
1GB.bin 88%[================> ] 888.19M 3.04MB/s in 2m 14s
As you can see, it is on pair with my PC box (single threaded), not writing the complete 1 GB file could have helped Radxa X with the result, but I am using a USB stick which is slow as hell.
You should consider that your PC may have more threads and cores.
Conclusion:
Using a Desktop (ubuntu and others) requires you to debloat (remove unnecessary services) to have a mean and lean distro , then you can have similar results.
Thanks. I did some tests from CLI and in fact the speed is
Download: 836.23 Mbps (data used: 871.7 MB)
Upload: 180.36 Mbps (data used: 229.0 MB)
while on the usual server but from a browser it does not go beyond 130 MB
Using everything with Hotspot, however, the connected devices do not go beyond 30 MB in WIFI 5 GHZ. Can the problem be corrected?
4 GB dram is minimum requirement for a relatively good experience. Browsers fire a lot of threads. Tried Brave?
I think hotspot Is slow by nature with mobile wifi chips. Try with your phone and compare the results
PS:
Try updating the wifi firmware as per kotori’s instructions. Wifi improve a lot with the new firmware.
I have the 4 gb version … I was hoping they were enough. I installed Brave, but the connection is always slow. With the Hotspot it is very slow
