Some logs:
2024-12-25 23:45:13.172 T:3023 info <general>: -----------------------------------------------------------------------
2024-12-25 23:45:13.172 T:3023 info <general>: Starting Kodi from Debian (20.1 Debian package version: 2:20.1+dfsg-1). Platform: Linux ARM 64-bit
2024-12-25 23:45:13.172 T:3023 info <general>: Using Release Kodi from Debian x64
2024-12-25 23:45:13.172 T:3023 info <general>: Kodi from Debian compiled 2023-03-12 by GCC 12.2.0 for Linux ARM 64-bit version 6.1.15 (393487)
2024-12-25 23:45:13.173 T:3023 info <general>: Running on Debian GNU/Linux 12 (bookworm), kernel: Linux ARM 64-bit version 6.1.43-20-rk2312
2024-12-25 23:45:13.178 T:3023 info <general>: FFmpeg version/source: 5.1.6-0+deb12u1
2024-12-25 23:45:13.178 T:3023 info <general>: 8 CPU cores available
2024-12-25 23:45:13.178 T:3023 info <general>: ARM Features: Neon enabled
2024-12-25 23:45:13.178 T:3023 info <general>: special://xbmc/ is mapped to: /usr/share/kodi
2024-12-25 23:45:13.178 T:3023 info <general>: special://xbmcbin/ is mapped to: /usr/lib/aarch64-linux-gnu/kodi
2024-12-25 23:45:13.178 T:3023 info <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/aarch64-linux-gnu/kodi/addons
2024-12-25 23:45:13.178 T:3023 info <general>: special://masterprofile/ is mapped to: /home/radxa/.kodi/userdata
2024-12-25 23:45:13.178 T:3023 info <general>: special://envhome/ is mapped to: /home/radxa
2024-12-25 23:45:13.178 T:3023 info <general>: special://home/ is mapped to: /home/radxa/.kodi
2024-12-25 23:45:13.178 T:3023 info <general>: special://temp/ is mapped to: /home/radxa/.kodi/temp
2024-12-25 23:45:13.178 T:3023 info <general>: special://logpath/ is mapped to: /home/radxa/.kodi/temp
2024-12-25 23:45:13.178 T:3023 info <general>: Webserver extra whitelist paths:
2024-12-25 23:45:13.178 T:3023 info <general>: The executable running is: /usr/lib/aarch64-linux-gnu/kodi/kodi.bin
2024-12-25 23:45:13.178 T:3023 info <general>: Local hostname: rock-5c
2024-12-25 23:45:13.178 T:3023 info <general>: Log File is located: /home/radxa/.kodi/temp/kodi.log
2024-12-25 23:45:13.180 T:3023 info <general>: -----------------------------------------------------------------------
2024-12-25 23:45:13.185 T:3023 info <general>: loading settings
2024-12-25 23:45:13.188 T:3023 info <general>: special://profile/ is mapped to: special://masterprofile/
2024-12-25 23:45:13.208 T:3023 info <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2024-12-25 23:45:13.208 T:3023 info <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2024-12-25 23:45:13.208 T:3023 info <general>: Default Video Player: VideoPlayer
2024-12-25 23:45:13.208 T:3023 info <general>: Default Audio Player: paplayer
2024-12-25 23:45:13.208 T:3023 info <general>: Disabled debug logging due to GUI setting. Level 0.
2024-12-25 23:45:13.208 T:3023 info <general>: Log level changed to "info"
2024-12-25 23:45:13.211 T:3023 info <general>: creating subdirectories
2024-12-25 23:45:13.211 T:3023 info <general>: userdata folder: special://masterprofile/
2024-12-25 23:45:13.211 T:3023 info <general>: recording folder:
2024-12-25 23:45:13.211 T:3023 info <general>: screenshots folder:
2024-12-25 23:45:13.220 T:3023 info <general>: Running database version Addons33
2024-12-25 23:45:13.738 T:3023 info <general>: CAddonMgr::FindAddons:
2024-12-25 23:45:13.743 T:3023 info <general>: CAddonMgr::FindAddons: resource.language.en_us v10.0.55 installed
2024-12-25 23:45:13.771 T:3023 info <general>: Selected Logind/UPower as PowerSyscall
2024-12-25 23:45:13.833 T:3023 info <general>: Selected UPower as PowerSyscall
2024-12-25 23:45:13.835 T:3023 error <general>: DBus error: org.freedesktop.DBus.Error.InvalidArgs - No such property “CanSuspend”
2024-12-25 23:45:13.836 T:3023 error <general>: DBus error: org.freedesktop.DBus.Error.InvalidArgs - No such property “CanHibernate”
2024-12-25 23:45:13.863 T:3023 info <general>: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
2024-12-25 23:45:13.937 T:3023 info <general>: Available videomodes (xrandr):
2024-12-25 23:45:13.937 T:3023 info <general>: Output 'HDMI-1' has 45 modes
2024-12-25 23:45:13.937 T:3023 info <general>: ID:0x44 Name:2560x1440 Refresh:143.999207 Width:2560 Height:1440
2024-12-25 23:45:13.937 T:3023 info <general>: Pixel Ratio: 0.999442
2024-12-25 23:45:13.939 T:3023 info <general>: CApplication::CreateGUI - using the x11 windowing system
2024-12-25 23:45:13.939 T:3023 info <general>: Checking resolution 16
2024-12-25 23:45:14.056 T:3023 info <general>: RetroPlayer[RENDER]: Registering renderer factory for OpenGL
2024-12-25 23:45:14.167 T:3028 info <general>: Loading special://xbmc/system/Lircmap.xml
2024-12-25 23:45:14.174 T:3028 info <general>: * Adding remote mapping for device 'mceusb'
2024-12-25 23:45:14.174 T:3028 info <general>: * Adding remote mapping for device 'XboxDVDDongle'
2024-12-25 23:45:14.174 T:3028 info <general>: * Adding remote mapping for device 'Microsoft_Xbox'
2024-12-25 23:45:14.174 T:3028 info <general>: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'anysee'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'iMON-PAD'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'Antec_Veris_RM200'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'MCE_via_iMON'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'TwinHanRemote'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'linux-input-layer'
2024-12-25 23:45:14.175 T:3028 info <general>: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'mediacenter'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'devinput'
2024-12-25 23:45:14.175 T:3028 info <general>: * Adding remote mapping for device 'devinput-32'
2024-12-25 23:45:14.176 T:3028 info <general>: * Adding remote mapping for device 'devinput-64'
2024-12-25 23:45:14.185 T:3023 info <general>: Using visual 0x21
2024-12-25 23:45:14.197 T:3023 warning <general>: Failed to get an OpenGL context supporting core profile 3.2, using legacy mode with reduced feature set
2024-12-25 23:45:14.273 T:3023 info <general>: Using visual 0x21
2024-12-25 23:45:14.294 T:3023 info <general>: VDPAU::CreateContext - creating decoder context
2024-12-25 23:45:14.298 T:3023 info <general>: vdp_device = 0xcfc62ea0 vdp_st = 0x000001
2024-12-25 23:45:14.298 T:3023 error <general>: (VDPAU) unable to init VDPAU - vdp_st = 0x1. Falling back.
2024-12-25 23:45:14.298 T:3023 info <general>: CRenderSystemGL::InitRenderSystem - Version: 3.1 Mesa 24.2~git2407100600.ae3e0a~oibaf~j (git-ae3e0ae 2024-07-10 jammy-oibaf-ppa), Major: 3, Minor: 1
2024-12-25 23:45:14.299 T:3023 info <general>: GL_VENDOR = Mesa
2024-12-25 23:45:14.299 T:3023 info <general>: GL_RENDERER = Mali-G610 (Panfrost)
2024-12-25 23:45:14.299 T:3023 info <general>: GL_VERSION = 3.1 Mesa 24.2~git2407100600.ae3e0a~oibaf~j (git-ae3e0ae 2024-07-10 jammy-oibaf-ppa)
2024-12-25 23:45:14.299 T:3023 info <general>: GL_SHADING_LANGUAGE_VERSION = 1.40
2024-12-25 23:45:14.299 T:3023 info <general>: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_fragment_shader GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_NV_half_float GL_APPLE_packed_pixels GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_EXT_texture_buffer_object GL_AMD_texture_texture4 GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_buffer_object GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_compatibility GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_EXT_texture_storage GL_MESA_texture_signed_rgba GL_NV_copy_image GL_ARB_draw_indirect GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_subroutine GL_ARB_texture_compression_bptc GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_EXT_direct_state_access GL_AMD_multi_draw_indirect GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_framebuffer_no_attachments GL_ARB_invalidate_subdata GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_shader_image_size GL_ARB_shader_storage_buffer_object GL_ARB_stencil_texturing GL_ARB_texture_buffer_range GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_enhanced_layouts GL_ARB_internalformat_query2 GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_shading_language_include GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_stencil8 GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_debug_label GL_EXT_shader_framebuffer_fetch GL_EXT_shader_integer_mix GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_direct_state_access GL_ARB_get_texture_sub_image GL_EXT_polygon_offset_clamp GL_EXT_shader_image_load_formatted GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_ARB_parallel_shader_compile GL_ARB_shader_atomic_counter_ops GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_RG8 GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_MESA_shader_integer_functions GL_ARB_polygon_offset_clamp GL_ARB_texture_filter_anisotropic GL_KHR_parallel_shader_compile GL_EXT_EGL_image_storage GL_EXT_shader_framebuffer_fetch_non_coherent GL_INTEL_blackhole_render GL_EXT_EGL_sync GL_EXT_EGL_image_storage_compression GL_NV_ES1_1_compatibility GL_MESA_texture_const_bandwidth
2024-12-25 23:45:14.343 T:3023 error <general>: CYUVShaderGLSL::CYUVShaderGLSL - failed to open file gl_shader_frag_texture_lim.glsl
2024-12-25 23:45:14.343 T:3023 info <general>: GL: No pixel shader, fixed pipeline in use
2024-12-25 23:45:14.375 T:3023 error <general>: CYUVShaderGLSL::CYUVShaderGLSL - failed to open file gl_shader_frag_texture_lim.glsl
2024-12-25 23:45:14.375 T:3023 info <general>: GL: No pixel shader, fixed pipeline in use
2024-12-25 23:45:14.382 T:3023 info <general>: GL: Maximum texture width: 8192
2024-12-25 23:45:14.494 T:3023 info <general>: GL: Enabling VSYNC
2024-12-25 23:45:14.495 T:3023 info <general>: load keymapping
2024-12-25 23:45:14.497 T:3023 info <general>: Loading special://xbmc/system/keymaps/appcommand.xml
2024-12-25 23:45:14.512 T:3023 info <general>: GUI format 2560x1440, Display HDMI-1: 2560x1440 @ 144.00Hz
2024-12-25 23:45:14.519 T:3037 warning <general>: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2024-12-25 23:45:14.520 T:3037 info <general>: Found 1 Lists of Devices
2024-12-25 23:45:14.520 T:3037 info <general>: Enumerated PULSE devices:
2024-12-25 23:45:14.520 T:3037 info <general>: Device 1
2024-12-25 23:45:14.520 T:3037 info <general>: m_deviceName : Default
2024-12-25 23:45:14.520 T:3037 info <general>: m_displayName : Default
2024-12-25 23:45:14.520 T:3037 info <general>: m_displayNameExtra: Default Output Device (PULSEAUDIO)
2024-12-25 23:45:14.520 T:3037 info <general>: m_deviceType : AE_DEVTYPE_PCM
2024-12-25 23:45:14.520 T:3037 info <general>: m_channels : FL, FR
2024-12-25 23:45:14.520 T:3037 info <general>: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2024-12-25 23:45:14.520 T:3037 info <general>: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
2024-12-25 23:45:14.520 T:3037 info <general>: m_streamTypes : No passthrough capabilities
2024-12-25 23:45:14.520 T:3037 info <general>: Device 2
2024-12-25 23:45:14.520 T:3037 info <general>: m_deviceName : auto_null
2024-12-25 23:45:14.520 T:3037 info <general>: m_displayName : Dummy Output
2024-12-25 23:45:14.520 T:3037 info <general>: m_displayNameExtra: Dummy Output (PULSEAUDIO)
2024-12-25 23:45:14.520 T:3038 info <general>: CActiveAESink::OpenSink - initialize sink
2024-12-25 23:45:14.543 T:3038 info <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms Periodsize 100 ms
2024-12-25 23:45:14.545 T:3023 info <general>: CLangInfo: loading resource.language.en_gb language information...
2024-12-25 23:45:14.547 T:3023 info <general>: global locale set to en_US.UTF-8
2024-12-25 23:45:14.547 T:3023 info <general>: CLangInfo: loading resource.language.en_gb language strings...
2024-12-25 23:45:14.603 T:3041 info <general>: Running database version Addons33
2024-12-25 23:45:14.605 T:3041 info <general>: Running database version ViewModes6
2024-12-25 23:45:14.606 T:3041 info <general>: Running database version Textures13
2024-12-25 23:45:14.612 T:3041 info <general>: Running database version MyMusic82
2024-12-25 23:45:14.622 T:3041 info <general>: Running database version MyVideos121
2024-12-25 23:45:14.624 T:3041 info <general>: Running database version TV40
2024-12-25 23:45:14.627 T:3041 info <general>: Running database version Epg16
2024-12-25 23:45:14.680 T:3023 info <general>: Unloaded skin
2024-12-25 23:45:14.683 T:3023 info <general>: load skin from: /usr/share/kodi/addons/skin.estuary/ (version: 3.0.10)
2024-12-25 23:45:14.683 T:3023 info <general>: load fonts for skin...
2024-12-25 23:45:14.684 T:3023 info <general>: Loading skin includes from /usr/share/kodi/addons/skin.estuary/xml/Includes.xml
2024-12-25 23:45:14.721 T:3023 info <general>: LoadFonts: Loading fonts from '/usr/share/kodi/addons/skin.estuary/xml/Font.xml'
2024-12-25 23:45:14.734 T:3023 info <general>: LoadTimers: Trying to load skin timers from /usr/share/kodi/addons/skin.estuary/xml/Timers.xml
2024-12-25 23:45:14.736 T:3023 info <general>: load new skin...
2024-12-25 23:45:14.736 T:3023 info <general>: Loading custom window XMLs from skin path /usr/share/kodi/addons/skin.estuary/xml
2024-12-25 23:45:14.743 T:3023 info <general>: initialize new skin...
2024-12-25 23:45:14.743 T:3023 info <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.744 T:3023 info <general>: Loading skin file: DialogNotification.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.745 T:3023 info <general>: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.761 T:3023 info <general>: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.763 T:3023 info <general>: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.764 T:3023 info <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.765 T:3023 info <general>: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.766 T:3023 info <general>: Loading skin file: Custom_1109_TopBarOverlay.xml, load type: LOAD_ON_GUI_INIT
2024-12-25 23:45:14.771 T:3023 info <general>: Loading resource://resource.uisounds.kodi/sounds.xml
2024-12-25 23:45:14.846 T:3023 info <general>: skin loaded...
2024-12-25 23:45:14.846 T:3023 info <general>: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
2024-12-25 23:45:14.847 T:3023 info <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2024-12-25 23:45:14.984 T:3023 warning <general>: JSONRPC: Could not parse type "Setting.Details.SettingList"
2024-12-25 23:45:14.984 T:3023 info <general>: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
2024-12-25 23:45:14.984 T:3023 info <general>: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
2024-12-25 23:45:14.995 T:3023 info <general>: JSONRPC v13.0.0: Successfully initialized
2024-12-25 23:45:14.995 T:3023 info <general>: [Media Detection] starting service for optical media detection
2024-12-25 23:45:15.002 T:3023 info <general>: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2024-12-25 23:45:15.003 T:3023 info <general>: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2024-12-25 23:45:15.004 T:3023 info <general>: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2024-12-25 23:45:15.005 T:3023 info <general>: Loaded playercorefactory configuration
2024-12-25 23:45:15.005 T:3023 info <general>: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2024-12-25 23:45:15.005 T:3023 info <general>: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2024-12-25 23:45:15.005 T:3023 info <general>: removing tempfiles
2024-12-25 23:45:15.006 T:3023 info <general>: initialize done
2024-12-25 23:45:15.006 T:3023 info <general>: Running the application...
2024-12-25 23:45:15.012 T:3023 info <general>: starting zeroconf publishing
2024-12-25 23:45:15.012 T:3052 info <general>: ES: Starting UDP Event server on port 9777
2024-12-25 23:45:15.012 T:3052 info <general>: UDP: Listening on port 9777 (ipv6 : false)
2024-12-25 23:45:15.012 T:3023 info <general>: JSONRPC Server: Successfully initialized
2024-12-25 23:45:15.013 T:3023 info <general>: CWSDiscoveryListenerUDP::Start - Started
2024-12-25 23:45:15.013 T:3054 info <general>: CWSDiscoveryListenerUDP::Stop - Stopped
2024-12-25 23:45:15.054 T:3047 info <general>: Register - new cec device registered on cec->Linux: CEC Adapter (0000:0000)
2024-12-26 00:30:19.738 T:3038 info <general>: CActiveAESink::OpenSink - initialize sink
2024-12-26 00:30:19.784 T:3038 info <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms Periodsize 100 ms
2024-12-26 00:30:21.096 T:3023 info <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2024-12-26 00:30:22.735 T:3023 info <general>: Attempting to default to:
2024-12-26 00:30:22.735 T:3023 info <general>: Loading skin file: FileManager.xml, load type: KEEP_IN_MEMORY
2024-12-26 00:30:30.055 T:3023 info <general>: Loading skin file: SettingsSystemInfo.xml, load type: KEEP_IN_MEMORY
2024-12-26 00:30:30.085 T:3373 error <general>: CCurlFile::Exists - <http://www.msftconnecttest.com/connecttest.txt> Failed: Couldn't resolve host name(6)
2024-12-26 00:30:30.086 T:3373 error <general>: CCurlFile::Exists - <http://www.w3.org/> Failed: Couldn't resolve host name(6)
2024-12-26 00:35:30.363 T:3038 info <general>: CActiveAESink::OpenSink - initialize sink
2024-12-26 00:35:30.396 T:3038 info <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms Periodsize 100 ms
2024-12-26 00:35:31.408 T:3373 error <general>: CCurlFile::Exists - <http://www.msftconnecttest.com/connecttest.txt> Failed: Couldn't resolve host name(6)
2024-12-26 00:35:31.410 T:3373 error <general>: CCurlFile::Exists - <http://www.w3.org/> Failed: Couldn't resolve host name(6)
2024-12-26 00:35:42.529 T:3023 info <general>: Loading skin file: EventLog.xml, load type: KEEP_IN_MEMORY
2024-12-26 00:35:50.133 T:3023 info <general>: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
2024-12-26 00:35:52.267 T:3023 error <CSettingString>: unknown options filler "libinputkeyboardlayout" of "input.libinputkeyboardlayout"
2024-12-26 00:35:52.802 T:3038 info <general>: CActiveAESink::OpenSink - initialize sink
2024-12-26 00:35:54.181 T:3023 error <CSettingString>: unknown options filler "libinputkeyboardlayout" of "input.libinputkeyboardlayout"
2024-12-26 00:35:57.802 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:35:57.803 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:00.302 T:3037 info <general>: Skipped 3 duplicate messages..
2024-12-26 00:36:00.302 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:05.303 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:05.303 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:07.802 T:3037 info <general>: Skipped 6 duplicate messages..
2024-12-26 00:36:07.802 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:07.815 T:3023 error <CSettingString>: unknown options filler "libinputkeyboardlayout" of "input.libinputkeyboardlayout"
2024-12-26 00:36:12.802 T:3037 info <general>: Skipped 1 duplicate messages..
2024-12-26 00:36:12.802 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:12.802 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:14.035 T:3023 info <CSettingString>: Skipped 22 duplicate messages..
2024-12-26 00:36:14.035 T:3023 error <CSettingString>: unknown options filler "libinputkeyboardlayout" of "input.libinputkeyboardlayout"
2024-12-26 00:36:15.302 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:20.302 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:20.303 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:22.802 T:3037 info <general>: Skipped 23 duplicate messages..
2024-12-26 00:36:22.802 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:23.942 T:3038 info <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms Periodsize 100 ms
2024-12-26 00:36:23.948 T:3038 info <general>: CActiveAESink::OpenSink - initialize sink
2024-12-26 00:36:24.829 T:3023 error <CSettingString>: unknown options filler "libinputkeyboardlayout" of "input.libinputkeyboardlayout"
2024-12-26 00:36:27.803 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:27.803 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:30.303 T:3037 info <general>: Skipped 3 duplicate messages..
2024-12-26 00:36:30.303 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:35.303 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:35.303 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:37.801 T:3037 info <general>: Skipped 13 duplicate messages..
2024-12-26 00:36:37.801 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:41.441 T:3023 info <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
2024-12-26 00:36:42.802 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:42.802 T:3037 warning <general>: CActiveAE::StateMachine - signal: 1 from port: OutputDataPort not handled for state: 2
2024-12-26 00:36:45.301 T:3037 info <general>: Skipped 9 duplicate messages..
2024-12-26 00:36:45.301 T:3037 error <general>: ActiveAE::FlushEngine - failed to flush
2024-12-26 00:36:45.353 T:3023 info <general>: Stopping the application...
2024-12-26 00:36:45.353 T:3023 info <general>: Stopping player
2024-12-26 00:36:45.353 T:3023 info <general>: Storing total System Uptime
2024-12-26 00:36:45.353 T:3023 info <general>: Saving settings
2024-12-26 00:36:45.360 T:3023 info <general>: Saving skin settings
2024-12-26 00:36:45.361 T:3023 info <general>: Stopping all
2024-12-26 00:36:45.361 T:3023 info <general>: ES: Stopping event server
2024-12-26 00:36:45.361 T:3023 info <general>: stopping zeroconf publishing
2024-12-26 00:36:45.592 T:3052 info <general>: ES: UDP Event server stopped
2024-12-26 00:36:50.301 T:3037 error <general>: ActiveAE::InitSink - failed to init
2024-12-26 00:36:55.097 T:3038 info <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms Periodsize 100 ms
2024-12-26 00:37:26.211 T:3023 info <general>: Application stopped
2024-12-26 00:37:29.088 T:3023 info <general>: unload skin
2024-12-26 00:37:29.189 T:3023 info <general>: Unloaded skin
2024-12-26 00:37:29.192 T:3023 info <general>: unload sections
2024-12-26 00:37:29.195 T:3023 info <general>: CWSDiscoveryListenerUDP::Stop - Stopped
2024-12-26 00:37:29.226 T:3023 info <general>: XRANDR: /usr/lib/aarch64-linux-gnu/kodi/kodi-xrandr --screen 0 --output HDMI-1 --mode 0x44
2024-12-26 00:37:29.252 T:3023 info <general>: Exiting the application...
