Kernel with working cpufreq
Hi, I’m planning to use Radxa ZERO 3E in my project. For validation I’ve installed Gentoo on it with the mainline kernel (tried 6.14.6 and 6.15.0-rc5) and U-Boot (v2025.04). Everything that I need is working: Ethernet, SD card, I2C, USB, hwmon, and performance is more than enough. Unfortunately, cpufreq doesn’t seem to work, and I can’t test max power draw and max temperature/throttling under maximum load.
I’ve also built a kernel using BSP (./bsp linux rk356x) and extracted files from it (linux-image-5.10.160-1-rk356x_5.10.160-1_arm64.deb) into the right places, plus copied the device tree (rk3566-radxa-zero3.dtb). But when I try to boot it, there is nothing on the serial console, and the green LED is constantly on, which I think means it froze.
Where can I find a kernel with a working cpufreq, or what am I doing wrong with the BSP kernel?
U-Boot command to run the BSP kernel:
env set bootargs root=/dev/mmcblk0p4 ipv6.disable=1 rw console=ttyS2,115200; load mmc 1:3 $fdt_addr_r rk3566-radxa-zero-3e-5.10.160.dtb ; load mmc 1:3 $kernel_addr_r vmlinuz-5.10.160-1-rk356x; booti $kernel_addr_r - $fdt_addr_r
EDIT:
I’ve made some digging in device tree, and I changed baud to 115200. It booted, but I’m getting rcu stalls. Unfortunately, I don’t have any converter that works with 1.5M baud rate.
[ 71.361654] rcu: 1-…: (18000 ticks this GP) idle=6fe/1/0x4000000000000002 softirq=18/18 fqs=5995
[ 251.095198] rcu: INFO: rcu_sched self-detected stall on CPU
[ 251.095256] rcu: 1-…: (70422 ticks this GP) idle=6fe/1/0x4000000000000002 softirq=18/18 fqs=23857
[ 429.858471] rcu: INFO: rcu_sched self-detected stall on CPU
[ 429.858528] rcu: 1-…: (121039 ticks this GP) idle=6fe/1/0x4000000000000002 softirq=18/18 fqs=41515
I bought a new UART adapter and did some tests with building kernel on radxa-zero3_bookworm_kde_t2.output.img, results:
Current draw is about 0.7A, but for a moment it was about 0.9A during boot.
CPU temperature under load is about 83*C, and frequency is switching between 1.4 and 1.6GHz.
how did you install gentoo on it? And you were able to get the overlays working on gentoo?
Sorry for the late reply; this install was just a test to check if this board will be good for Docker Swarm. I was busy testing the Radxa Rock 5 ITX as a Docker manager and accidentally damaged it, and I’m slowly trying to repair it.
I prepared partitions on the SD card according to: https://opensource.rock-chips.com/wiki_Partitions, then unpacked stage3 into it and systemd-nspawn into it (using qemu_user_target). Then I build u-boot and kernel and put them into the right places.
I don’t have enough knowledge to mess with overlays – I just decompiled the working device tree, edited it and compiled it back.
