I am using an Edimax AC-1200 WiFi USB dongle to get a second WiFi connection on my system. I’m using kernel 4.4.154-110-rockchip-gcef30e88a9f5 and have built/installed the 88x2bu driver for this chip and all works just fine.
Then I made a copy of my MMC card and that copy also runs just fine.
Then I plugged that MMC card into a second Rock Pi 4 board with the same WiFi dongle and I get kernel panics and hangs on that system (see below). If I boot my system without the dongle, all is fine. If I boot with it, I see a panic like this 35 seconds or so after boot and any use of networking seems to hang the CPU. If I type “ifconfig eth0” for example; hangs the CPU. If I try to connect through the onboard WiFi, things will hang.
Is there some flash/firmware on the boards that I need to update that could be causing this? That’s the only thing I can think of that’s different. I am using the same MMC and the same physical dongle on both boards. Only the board where I built/configured the system works.
Thanks!
Here’s by dump if helpful:
Sep 7 18:18:51 localhost kernel: [ 2884.506394] usb 2-1: new high-speed USB device number 2 using ehci-platform
Sep 7 18:18:51 localhost kernel: [ 2884.640539] usb 2-1: New USB device found, idVendor=7392, idProduct=b822
Sep 7 18:18:51 localhost kernel: [ 2884.640564] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 7 18:18:51 localhost kernel: [ 2884.640579] usb 2-1: Product: AC1200 MU-MIMO USB2.0 Adapter
Sep 7 18:18:51 localhost kernel: [ 2884.640592] usb 2-1: Manufacturer: Realtek
Sep 7 18:18:51 localhost kernel: [ 2884.640606] usb 2-1: SerialNumber: 123456
Sep 7 18:19:12 localhost kernel: [ 2905.299179] BUG: spinlock bad magic on CPU#5, ip/13972
Sep 7 18:19:12 localhost kernel: [ 2905.299195] lock: 0xffffffc0e4aa7568, .magic: 00000000, .owner: /-1, .owner_cpu: 0
Sep 7 18:19:12 localhost kernel: [ 2905.299205] CPU: 5 PID: 13972 Comm: ip Tainted: G O 4.4.154-110-rockchip-gcef30e88a9f5 #1
Sep 7 18:19:12 localhost kernel: [ 2905.299211] Hardware name: ROCK PI 4B (DT)
Sep 7 18:19:12 localhost kernel: [ 2905.299216] Call trace:
Sep 7 18:19:12 localhost kernel: [ 2905.299235] [] dump_backtrace+0x0/0x220
Sep 7 18:19:12 localhost kernel: [ 2905.299243] [] show_stack+0x24/0x30
Sep 7 18:19:12 localhost kernel: [ 2905.299252] [] dump_stack+0x98/0xc0
Sep 7 18:19:12 localhost kernel: [ 2905.299260] [] spin_dump+0x84/0xa4
Sep 7 18:19:12 localhost kernel: [ 2905.299267] [] spin_bug+0x30/0x3c
Sep 7 18:19:12 localhost kernel: [ 2905.299273] [] do_raw_spin_lock+0x40/0x164
Sep 7 18:19:12 localhost kernel: [ 2905.299283] [] _raw_spin_lock_irqsave+0x28/0x38
Sep 7 18:19:12 localhost kernel: [ 2905.299612] [] wl_cfg80211_netdev_notifier_call+0x204/0x2a8 [bcmdhd]
Sep 7 18:19:12 localhost kernel: [ 2905.299622] [] notifier_call_chain+0x70/0x90
Sep 7 18:19:12 localhost kernel: [ 2905.299629] [] raw_notifier_call_chain+0x3c/0x4c
Sep 7 18:19:12 localhost kernel: [ 2905.299638] [] call_netdevice_notifiers_info+0x64/0x74
Sep 7 18:19:12 localhost kernel: [ 2905.299644] [] call_netdevice_notifiers+0x2c/0x38
Sep 7 18:19:12 localhost kernel: [ 2905.299650] [] __dev_close_many+0x9c/0xe0
Sep 7 18:19:12 localhost kernel: [ 2905.299657] [] __dev_close+0x2c/0x44
Sep 7 18:19:12 localhost kernel: [ 2905.299663] [] __dev_change_flags+0xa8/0x13c
Sep 7 18:19:12 localhost kernel: [ 2905.299668] [] dev_change_flags+0x34/0x70
Sep 7 18:19:12 localhost kernel: [ 2905.299676] [] do_setlink+0x400/0x844
Sep 7 18:19:12 localhost kernel: [ 2905.299683] [] rtnl_newlink+0x34c/0x648
Sep 7 18:19:12 localhost kernel: [ 2905.299690] [] rtnetlink_rcv_msg+0x1a0/0x1a8
Sep 7 18:19:12 localhost kernel: [ 2905.299699] [] netlink_rcv_skb+0x78/0xcc
Sep 7 18:19:12 localhost kernel: [ 2905.299706] [] rtnetlink_rcv+0x2c/0x3c
Sep 7 18:19:12 localhost kernel: [ 2905.299713] [] netlink_unicast+0x160/0x200
Sep 7 18:19:12 localhost kernel: [ 2905.299720] [] netlink_sendmsg+0x2ec/0x30c
Sep 7 18:19:12 localhost kernel: [ 2905.299728] [] sock_sendmsg+0x4c/0x68
Sep 7 18:19:12 localhost kernel: [ 2905.299735] [] ___sys_sendmsg+0x1dc/0x228
Sep 7 18:19:12 localhost kernel: [ 2905.299741] [] __sys_sendmsg+0x50/0x78
Sep 7 18:19:12 localhost kernel: [ 2905.299746] [] SyS_sendmsg+0x38/0x50
Sep 7 18:19:12 localhost kernel: [ 2905.299753] [] el0_svc_naked+0x24/0x28
Sep 7 18:19:12 localhost kernel: [ 2905.299765] Unable to handle kernel NULL pointer dereference at virtual address 00000000
Sep 7 18:19:12 localhost kernel: [ 2905.299770] pgd = ffffffc0df68e000
Sep 7 18:19:12 localhost kernel: [ 2905.299774] [00000000] *pgd=0000000000000000, *pud=0000000000000000
Sep 7 18:19:12 localhost kernel: [ 2905.299786] Internal error: Oops: 96000005 [#1] SMP
Sep 7 18:19:12 localhost kernel: [ 2905.299792] Modules linked in: 88x2bu(O) w1_therm w1_gpio wire bcmdhd autofs4
Sep 7 18:19:12 localhost kernel: [ 2905.299815] CPU: 5 PID: 13972 Comm: ip Tainted: G O 4.4.154-110-rockchip-gcef30e88a9f5 #1
Sep 7 18:19:12 localhost kernel: [ 2905.299820] Hardware name: ROCK PI 4B (DT)
Sep 7 18:19:12 localhost kernel: [ 2905.299824] task: ffffffc0ddc3c600 task.stack: ffffffc0debb0000
Sep 7 18:19:12 localhost kernel: [ 2905.300140] PC is at wl_cfg80211_netdev_notifier_call+0x218/0x2a8 [bcmdhd]
Sep 7 18:19:12 localhost kernel: [ 2905.300457] LR is at wl_cfg80211_netdev_notifier_call+0x204/0x2a8 [bcmdhd]
Sep 7 18:19:12 localhost kernel: [ 2905.300463] pc : [] lr : [] pstate: 800001c5
Sep 7 18:19:12 localhost kernel: [ 2905.300467] sp : ffffffc0debb3560
Sep 7 18:19:12 localhost kernel: [ 2905.300471] x29: ffffffc0debb3560 x28: 0000000000000000
Sep 7 18:19:12 localhost kernel: [ 2905.300480] x27: ffffffc0e5ed7b00 x26: ffffffc0debb3918
Sep 7 18:19:12 localhost kernel: [ 2905.300488] x25: ffffffc0debd5210 x24: ffffff800119f200
Sep 7 18:19:12 localhost kernel: [ 2905.300495] x23: ffffff80011f8978 x22: ffffffc0e4aa7568
Sep 7 18:19:12 localhost kernel: [ 2905.300502] x21: 0000000000000009 x20: ffffffc0df58c000
Sep 7 18:19:12 localhost kernel: [ 2905.300509] x19: ffffffc0e4aa6fc0 x18: 0000000000000005
Sep 7 18:19:12 localhost kernel: [ 2905.300516] x17: 0000007f7f9e05e8 x16: ffffff8008a3a338
Sep 7 18:19:12 localhost kernel: [ 2905.300523] x15: 0000000000000000 x14: 000000000000000a
Sep 7 18:19:12 localhost kernel: [ 2905.300530] x13: ffffff80893f48cb x12: 0000000000000030
Sep 7 18:19:12 localhost kernel: [ 2905.300537] x11: 0000000000003ff0 x10: 0000000000000005
Sep 7 18:19:12 localhost kernel: [ 2905.300544] x9 : ffffffc0debb3400 x8 : 00000040eed2d000
Sep 7 18:19:12 localhost kernel: [ 2905.300551] x7 : 0000000000003fff x6 : 00000000000011b0
Sep 7 18:19:12 localhost kernel: [ 2905.300558] x5 : 0000000000000000 x4 : ffffffffffffee50
Sep 7 18:19:12 localhost kernel: [ 2905.300565] x3 : 00000040eed2d000 x2 : ffffffffffffee50
Sep 7 18:19:12 localhost kernel: [ 2905.300572] x1 : ffffffc0e4aa7558 x0 : 0000000000000140
[ details of memory dump deleted ]
Sep 7 18:19:12 localhost kernel: [ 2905.304333] [] wl_cfg80211_netdev_notifier_call+0x218/0x2a8 [bcmdhd]
Sep 7 18:19:12 localhost kernel: [ 2905.304341] [] notifier_call_chain+0x70/0x90
Sep 7 18:19:12 localhost kernel: [ 2905.304348] [] raw_notifier_call_chain+0x3c/0x4c
Sep 7 18:19:12 localhost kernel: [ 2905.304356] [] call_netdevice_notifiers_info+0x64/0x74
Sep 7 18:19:12 localhost kernel: [ 2905.304362] [] call_netdevice_notifiers+0x2c/0x38
Sep 7 18:19:12 localhost kernel: [ 2905.304368] [] __dev_close_many+0x9c/0xe0
Sep 7 18:19:12 localhost kernel: [ 2905.304375] [] __dev_close+0x2c/0x44
Sep 7 18:19:12 localhost kernel: [ 2905.304380] [] __dev_change_flags+0xa8/0x13c
Sep 7 18:19:12 localhost kernel: [ 2905.304386] [] dev_change_flags+0x34/0x70
Sep 7 18:19:12 localhost kernel: [ 2905.304393] [] do_setlink+0x400/0x844
Sep 7 18:19:12 localhost kernel: [ 2905.304400] [] rtnl_newlink+0x34c/0x648
Sep 7 18:19:12 localhost kernel: [ 2905.304407] [] rtnetlink_rcv_msg+0x1a0/0x1a8
Sep 7 18:19:12 localhost kernel: [ 2905.304414] [] netlink_rcv_skb+0x78/0xcc
Sep 7 18:19:12 localhost kernel: [ 2905.304421] [] rtnetlink_rcv+0x2c/0x3c
Sep 7 18:19:12 localhost kernel: [ 2905.304427] [] netlink_unicast+0x160/0x200
Sep 7 18:19:12 localhost kernel: [ 2905.304434] [] netlink_sendmsg+0x2ec/0x30c
Sep 7 18:19:12 localhost kernel: [ 2905.304442] [] sock_sendmsg+0x4c/0x68
Sep 7 18:19:12 localhost kernel: [ 2905.304449] [] ___sys_sendmsg+0x1dc/0x228
Sep 7 18:19:12 localhost kernel: [ 2905.304454] [] __sys_sendmsg+0x50/0x78
Sep 7 18:19:12 localhost kernel: [ 2905.304460] [] SyS_sendmsg+0x38/0x50
Sep 7 18:19:12 localhost kernel: [ 2905.304466] [] el0_svc_naked+0x24/0x28
Sep 7 18:19:12 localhost kernel: [ 2905.304473] Code: 928235e4 91166261 d2823606 8b040042 (f948d843)
Sep 7 18:19:12 localhost kernel: [ 2905.309522] —[ end trace 998417cddfae61dd ]—
