looks like the kernel is installed but I always get errors - see below…
uname -a
Linux calypso 6.1.43-20-rk2312 #3e26818dc SMP Tue Nov 19 07:21:24 UTC 2024 aarch64 GNU/Linux
The image is an radxa image installed 14.4.2024 but
/var/lib/dkms/8852be/1.15.10.0.5.0-4/build/make.log
says:
warning: the compiler differs from the one used to build the kernel
The kernel was built by: aarch64-linux-gnu-gcc (Debian 10.2.1-6) 10.2.1 20210110
You are using: gcc (Debian 12.2.0-14) 12.2.0
HOW CAN I GET RID OF THIS ERROR WITHOUT REINSTALLING THE WHOLE OS.
Btw… new installs of the newest radxa AND armbian images are faulty!
One of them detaches the NIC at an kernel upgrade!
Tks
linux-image-6.1.43-20-rk2312 (6.1.43-20-3e26818dc) wird eingerichtet …
dkms: running auto installation service for kernel 6.1.43-20-rk2312.
Sign command: /lib/modules/6.1.43-20-rk2312/build/scripts/sign-file
Binary /lib/modules/6.1.43-20-rk2312/build/scripts/sign-file not found, modules
won’t be signed
Building module:
Cleaning build area…
make -j8 KERNELRELEASE=6.1.43-20-rk2312 -C /lib/modules/6.1.43-20-rk2312/build M
=/var/lib/dkms/8852be/1.15.10.0.5.0-4/build…(bad exit status: 2)
Error! Bad return status for module build on kernel: 6.1.43-20-rk2312 (aarch64)
Consult /var/lib/dkms/8852be/1.15.10.0.5.0-4/build/make.log for more information
won’t be signed
Building module:
=/var/lib/dkms/8852bu/1.15.7.112-2/build…(bad exit status: 2)
Consult /var/lib/dkms/8852bu/1.15.7.112-2/build/make.log for more information.
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
dkms: autoinstall for kernel: 6.1.43-20-rk2312 failed!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
update-initramfs: Generating /boot/initrd.img-6.1.43-20-rk2312
Rebuilding overlay data folder for ‘6.1.43-20-rk2312’…
Removing managed overlays…
Building list of compatible overlays…
Installing compatible overlays…
Reenable previously enabled overlays…
Commiting changes…
Overlay data folder has been successfully rebuilt.
P: Checking for EXTLINUX directory… found.
P: Writing config for vmlinuz-6.1.43-20-rk2312…
P: Writing config for vmlinuz-5.10.110-33-rockchip…
dpkg: Fehler beim Bearbeiten des Paketes linux-image-6.1.43-20-rk2312 (–configu
re):
»installiertes post-installation-Skript des Paketes linux-image-6.1.43-20-rk231
2«-Unterprozess gab den Fehlerwert 1 zurück
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von linux-image-rock-5b:
linux-image-rock-5b hängt ab von linux-image-6.1.43-20-rk2312; aber:
Paket linux-image-6.1.43-20-rk2312 ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten des Paketes linux-image-rock-5b (–configure):
Abhängigkeitsprobleme - verbleibt unkonfiguriert
Fehler traten auf beim Bearbeiten von:
linux-image-rock-5b
나는 Radxa 5b 보드에서 custom 운영체제를 사용하길 원합니다.
하지만 3번 과정에서 실패했습니다.
내 방법의 어느 과정이 틀렸나요?
이 문제를 해결할 방법이 있나요?
나는 balenaEtcher을 통해 ubuntu를 SD 카드에 설치 후 운영체제 실행에 성공했습니다.
다운로드 주소:(Sorry, new users can only put 2 links in a post.)
설치파일:ubuntu-24.10-preinstalled-desktop-arm64-rock-5b.img.xz
다음 두 지침을 따라 여러파일들을 생성시켰고, 3개의 파일을 Radxa 5b 보드의 ubuntu로 이동시켰습니다.
(커널 업데이트 테스트를 위해 커널 코드는 수정하지 않았습니다.)
다음 파일들이 debian 운영체제에서 동작을 한다면, rock 5b 보드에 debian 운영체제를 설치하고 싶습니다.
ubuntu 운영체제는 아래 주소에서 다운받았는데, 이중 debian 운영체제는 없었습니다. https://wiki.radxa.com/Rock5/downloads
어디에서 rock 5b 보드에서 동작가능한 debian 운영체제를 다운로드 할 수 있나요?
The only acceptable and most common standard would be the arrmbian image but this image seems to have a NIC driver problem as the NIC vanishes on an upgrade…
