JMICRON JMB575 on Marvell 88SE9235
4x Integral P5 120gb Sata SSD
4 ports JMICRON JMB575 to 1 port Marvell 88SE9235
        Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
        Output is in kBytes/sec
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4    35544    44268    49550    51575    25761    43033
          102400      16    97301   125804   117401   147397    82039   128312
          102400     512   324494   328787   346244   353206   269376   289570
          102400    1024   279255   372742   390811   404674   355661   318853
          102400   16384   425107   431510   450355   456180   456446   429949
2 ports JMICRON JMB575 to 2 ports Marvell 88SE9235
          102400       4    33528    44095    52373    52610    25227    44286
          102400      16    97618   127626   138240   145449    80568   117886
          102400     512   323600   332563   337137   346145   274899   281182
          102400    1024   303781   373326   399350   405075   356055   359329
          102400   16384   495194   619585   627739   629226   622326   623139
4 ports Marvell 88SE9235
          102400       4    33519    47927    52701    51023    26700    46382
          102400      16   105763   132604   138080   155514    87026   135111
          102400     512   276220   320320   311343   294629   267624   335363
          102400    1024   493565   522038   463105   470833   398584   522560
          102400   16384   687516   701200   625733   623531   555318   681535
We are working on JMB585 :slight_smile:
Stay tunned :slight_smile:
I got 2x of these @jack
https://www.ebay.co.uk/itm/Expansion-Card-1-to-5Port-SATA3-0-Controller-Motherboard-Multiplier-SATA-for-HDD/254262686554
Prob only ever use 2-3x ports on them though and use them as sata ‘splitters’ rather than loaded with 3-5 drives.
With 2-3 ports on the multiplier and the x4 port Marvell thats 8-12 disks with reasonable throughput.
