We are using the radxa zero in our product. We are having issues booting the OS with the pre-built binary.
The binary we are using is :
radxa-zero-debian-buster-xfce4-arm64-20220801-0339-mbr.img.xz
Unfortunatly, 50% of the time, we have this booting issue:
This issue can be partly remedied by flashing this bootloader after flashing the image:
https://dl.radxa.com/zero/images/loader/u-boot.bin.sd.bin
After flashing the new bootloader we have this message:
The bootloader is looking for the meson-g12a-radxa-zero.dtb file and cannot find it.
The reason it cannot find it is because the path is incorrect (amlogic/amlogic)
The solution is to load the radxa as a USB file storage (rz-udisk-loader.bin) and then copy the file at the correct location (creating a folder named amlogic). Then everything seems to work.
The issue is that we need to flash more than 1 radxa, so every step needed adds unnecessary time.
The possible solutions are
- Build the image with the latest boot loader (most direct approach)
- Build the bootloader with the correct path (reduce the step of having to create a folder with the file)
Would it be possible to release a new binary version with the latest bootloader and the correct path?
The latest images are from 2022
We can assist in testing the image
Thank you, best regards
