Yesterday I received my rock 5, now trying to set up a boot from the ssd.
Faced the following problem: at startup, the board is in an endless reboot. The bootloader from the wiki loaded without errors, Ubuntu image from the same wiki - too (there was a warning from parted that the gpt table does not use the entire volume of the ssd).
Once I was able to catch an error running across the screen in the photo
Ssd: samsung 970 evo plus
read errors appear when i plug in usb keyboard (and also when pull it out)
also tried Debian image, same issue, infinite reboot
When i tried different ssd (lite-on), board successfully booted into Ubuntu. When I executed sudo apt update && sudo apt upgrade -y, everything was ok, then I just rebooted the board and it is broken again. The same infinite reboot
Btw if i just use sd card, everything is OK. This issue occurs only with booting from ssd. But I don’t want to use sd card
I thought that this may be PD issue, but the behavior is inconsistent. Once it is just in an endless reboot, the second time it stops and displays an error message, the third time it loads, updates, and does not load after the update, and so on
In a few days my new Anker A2148 will arrive, which, according to the wiki, is stable. Will try with it and armbian too. But I really want to just use official Ubuntu image with nvme samsung ssd, setup k3s cluster and don’t waste my time on OS/boot issues
