I’ve been trying to use hardware encoding on a zero 3w, my current issue is
rga_api version 1.3.1_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
10000 is unsupport format now,pilese fix.
Which occurs and results in no viedo.
I’m also getting this
RgaBlit(1356) RGA_BLIT fail: Invalid argument RgaBlit(1357) RGA_BLIT fail: Invalid argument
fd-vir-phy-hnd-format[26, (nil), (nil), (nil), 0]
rect[0, 0, 1920, 1080, 3840, 1080, 65536, 0]
f-blend-size-rotation-col-log-mmu[0, 0, 0, 0, 0, 0, 1]
fd-vir-phy-hnd-format[31, (nil), (nil), (nil), 0]
rect[0, 0, 1920, 1080, 1920, 1088, 2560, 0]
This output the user patamaters when rga call blit fail
On all uses of the mpph264 ( or any hardware encoder ) whether they work or not.
For example
gst-launch-1.0 v4l2src num-buffers=512 device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! tee name=t ! queue ! mpph264enc ! queue ! h264parse ! mpegtsmux ! filesink location=/home/radxa/file.name.mp4
Saves a video that is viewable but throws lots of
fd-vir-phy-hnd-format[0, 0xffffa8014090, (nil), (nil), 0]
fd-vir-phy-hnd-format[34, (nil), (nil), (nil), 0]
in the process.
Any help is greatly appreciated.
Thanks
