Issues with armbian-config
I’ve developed some interesting issues im unsure of the cause for. I have 3 Rock5bs, all running armbian and they are all on 23.8.1.
On all three boards, I cannot change the kernel using the config. If go to System -> Other, hit space bar to acknowledge and then enter, it will retrieve files and then send you back to the system menu.
On two of the boards, I also cannot adjust the cpu fequencies nor the governor. You can change it to anything, and it will always stay at 408-2400Mhz using schedutil.
