Issue wtith SSD
Dunno with Armbian as long as those are nvme and not sata m.2 just ask in the Armbian forum.
To be honest slightly confused to why sata m.2 don’t work and sure its just a matter of a kernel module as it don’t make much sense but hey its got to be nvme.
Yes, those are NVME.
Ok, I will check first with image taken from here. Then eventually I will communicate that to Armbian.
@hijax_pl Is your wd ssd the SN500? I have the same drive right now (nvm, not the same drive, see below) but my board is still shipping. I also have the radxa’s ubuntu server image flashed to a microsd card ready, and I can report back as soon as I get my hands on my unit.
@tonyunreal , exactly it is WD Blue 3D Nand SSD 500 GB M.2 (WDS500G2B0B)
Works with my lap (Win10) while connecting via USB3 adapter.
You can try lspci if pciutils is installed and dmesg | grep pcie.
If its not showing up as a blk device its likely its not there but dmesg might give you some clues.
I really don’t know what is enabled in the armbian image and try the debian one from radxa after a apt-get update apt-get upgrade
@hijax_pl I don’t think we have the same drive. I googled the model number of yours (WDS500G2B0B) and found the Amazon page for it, it says SATA III instead of NVME:
My drive is the WDS500G1B0C and “NVME SSD” is written on the disk and on Amazon:
According to the FAQ, SATA drives are not supported by the Rock Pi 4B.
Has to be NVMe protocol not the earlier Sata protocol M.2 ssd, like I say dunno why but has to be nvme.
@anon77784915 Thank you very much for this comprehensive picture. Now it is clear I was fooled by a clerk. But what is more importantly thanks to you I have learned how to distinguish those modules visually.
I will use already bought WD SSD as external drive, and look for proper NVMe module (most of the web shops shows wrong picture as B-key is present and description clearly states “NVMe SSD”.
Having said that, could anybody verify that link?
https://www.wd.com/products/internal-ssd/wd-blue-sn500-nvme-ssd.html#WDS250G1B0C
NVMe as stated but with B-key?
I got my board today. My WDS500G1B0C is recognized under both radxa Ubuntu and Armbian, both images are the 64-bit 4.4 kernel ones. See below for screenshots.
(took me some time with the Armbian image because of this booting bug.)
Thanks @tonyunreal.
Then I will continue with ordering of WDS500G1B0C
Well I am even more confused now and its great that you got that working.
Obviously has nothing to do with m only keys which was confusing the hell out of me as why is my b+m 4 port sata adapter working?
I think it gets really confusing as there is legacy sata m2, nvme sata & just nvme.
But how to tell the difference between the first 2 I am completely confused.
Check this as I have purchased one for the hell of it.
https://www.mymemory.co.uk/integral-120gb-m-2-2280-pcie-nvme-ssd-drive.html
Its a pcie nvme sata m.2 :slight_smile:
Aint a clue as usual…
Received mine WD Blue 500GB
And yes, it is working fine :slight_smile:
Remember to edit /boot/hw_intfc.conf. and remove the hash from intfc:dtoverlay=pcie-gen2
Makes a huge diff in performance after a reboot.
Then sudo apt-get install iozone3
iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Then share the results with us :slight_smile:
Depending on rev of board v1.3/v1.4 you may have to buy a $1 flash chip and get the soldering iron out.
https://wiki.radxa.com/Rockpi4/Linux_system_runs_on_M.2_NVME_SSD
My armbian do not have /boot/hw_intfc.con file.
lspci
00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 0100
01:00.0 Non-Volatile memory controller: Sandisk Corp Device 5003 (rev 01)
And the test results
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4    70378    95856    69563    70056    32566    72206
          102400      16   136427   178523   169004   169452   112963   177023
          102400     512   333038   343379   318082   318938   309229   343023
          102400    1024   354563   362899   336900   337804   327674   366237
          102400   16384   365499   371415   360670   361154   360321   371168
Thats a problem then as you are prob at gen 1.0 speed how does armbian do the overlays as expect its in there?
The Integral 120GB M.2 2280 PCIE NVME works not the fastest but for £25 its OK.
It is set to gen2.0
        Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
        Output is in kBytes/sec
        Time Resolution = 0.000001 seconds.
        Processor cache size set to 1024 kBytes.
        Processor cache line size set to 32 bytes.
        File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
          102400       4    32351    39073    56177    52657    28777    40784
          102400      16   102608   131789   156747   140973    47277   115072
          102400     512   424581   450976   376851   379936   364507   427022
          102400    1024   438553   432823   407448   411767   405919   437925
          102400   16384   426185   432095   621528   632342   630287   440617
@stuartiannaylor, I have pasted wrong data, i.e. no sudo rights
Now is the correct printout:
$ sudo lspci -vv | grep -E 'PCI bridge|LnkCap'
00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 0100 (prog-if 00 [Normal decode])
                LnkCap: Port #0, Speed 2.5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us
                LnkCap: Port #0, Speed 8GT/s, Width x2, ASPM L1, Exit Latency L0s <256ns, L1 <8us
Its bit of a mixed bag your WD 250gb if you don’t mind me saying.
Its the small numbers that you need to look at as 99% of the time the bloack size will be 4k
Prob in effect will be faster than the integral even if the integral does boast the biggest numbers.
The Integral is far from brilliant but for a £25 that is quite a good match to the price of a RockPi4 its approx £35 after you purchase the M.2 extender which I think is well worth it.
You can try this for a ‘server’ more style as nothing really just works on a singular file or thread in reality.
cat >> google-compute.sh <<EOL
# Change this variable to the file path of the device you want to test
block_dev=\$file
# sh google-compute.sh to run
# install dependencies
sudo apt-get -y update
sudo apt-get install -y fio
# full write pass
sudo fio --name=writefile --size=10G --filesize=10G \
--filename=\$block_dev --bs=1M --nrfiles=1 \
--direct=1 --sync=0 --randrepeat=0 --rw=write --refill_buffers --end_fsync=1 \
--iodepth=200 --ioengine=libaio
# rand read
sudo fio --time_based --name=benchmark --size=10G --runtime=30 \
--filename=\$block_dev --ioengine=libaio --randrepeat=0 \
--iodepth=128 --direct=1 --invalidate=1 --verify=0 --verify_fatal=0 \
--numjobs=4 --rw=randread --blocksize=4k --group_reporting
# rand write
--numjobs=4 --rw=randwrite --blocksize=4k --group_reporting
EOL
chmod a+x google-compute.sh
Just copy and paste and it will create the test file for you just edit the file path
I am not really sure with the RockPi4 is the numjobs should be 2 or 6 IE number of CPUs.
I am going to hazard a guess at 6 and maybe this would be a reasonable overall test
maybe
cat >> rockpi4-nvme.sh <<EOL
block_dev=\$file
# sh rockpi4-nvme.sh to run
# rand write
sudo fio --name fio_test_file --direct=1 --rw=randwrite --bs=4k --size=1G --numjobs=6 --runtime=60 --filename=\$block_dev --group_reporting
# rand read
sudo fio --name fio_test_file --direct=1 --rw=randread --bs=4k --size=1G --numjobs=6 --runtime=60 --filename=\$block_dev --group_reporting
EOL
chmod a+x rockpi4-nvme.sh
Anyway the 2nd one gives me this and its prob the 2nd command that sort of simulates boot
rock@rockpi4:~$ sh rockpi4-nvme.sh
fio_test_file: (g=0): rw=randwrite, bs=4K-4K/4K-4K/4K-4K, ioengine=psync, iodepth=1
fio-2.16
Starting 6 processes
Jobs: 6 (f=6): [w(6)] [100.0% done] [0KB/28228KB/0KB /s] [0/7057/0 iops] [eta 00m:00s]
fio_test_file: (groupid=0, jobs=6): err= 0: pid=27300: Thu Jul 11 00:09:28 2019
  write: io=1670.4MB, bw=28505KB/s, iops=7126, runt= 60004msec
    clat (usec): min=81, max=68859, avg=831.29, stdev=1778.60
     lat (usec): min=82, max=68861, avg=832.63, stdev=1778.77
    clat percentiles (usec):
     |  1.00th=[   96],  5.00th=[  105], 10.00th=[  108], 20.00th=[  122],
     | 30.00th=[  151], 40.00th=[  764], 50.00th=[  788], 60.00th=[  820],
     | 70.00th=[  900], 80.00th=[  972], 90.00th=[ 1144], 95.00th=[ 1432],
     | 99.00th=[ 8256], 99.50th=[15936], 99.90th=[23936], 99.95th=[29312],
     | 99.99th=[40192]
    lat (usec) : 100=2.26%, 250=34.26%, 500=0.35%, 750=2.10%, 1000=42.78%
    lat (msec) : 2=15.50%, 4=1.44%, 10=0.47%, 20=0.68%, 50=0.17%
    lat (msec) : 100=0.01%
  cpu          : usr=1.74%, sys=9.68%, ctx=901635, majf=0, minf=115
  IO depths    : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     issued    : total=r=0/w=427600/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
     latency   : target=0, window=0, percentile=100.00%, depth=1
Run status group 0 (all jobs):
  WRITE: io=1670.4MB, aggrb=28504KB/s, minb=28504KB/s, maxb=28504KB/s, mint=60004msec, maxt=60004msec
Disk stats (read/write):
  nvme0n1: ios=0/426674, merge=0/0, ticks=0/31624, in_queue=31264, util=52.24%
fio_test_file: (g=0): rw=randread, bs=4K-4K/4K-4K/4K-4K, ioengine=psync, iodepth=1
fio-2.16
Jobs: 3 (f=3): [r(2),_(3),r(1)] [100.0% done] [111.4MB/0KB/0KB /s] [28.6K/0/0 iops] [eta 00m:00s]
fio_test_file: (groupid=0, jobs=6): err= 0: pid=27398: Thu Jul 11 00:10:14 2019
  read : io=6144.0MB, bw=140824KB/s, iops=35206, runt= 44676msec
    clat (usec): min=6, max=14780, avg=160.37, stdev=53.59
     lat (usec): min=6, max=14783, avg=161.03, stdev=53.66
     |  1.00th=[  114],  5.00th=[  120], 10.00th=[  124], 20.00th=[  133],
     | 30.00th=[  139], 40.00th=[  143], 50.00th=[  151], 60.00th=[  159],
     | 70.00th=[  171], 80.00th=[  183], 90.00th=[  207], 95.00th=[  231],
     | 99.00th=[  298], 99.50th=[  330], 99.90th=[  422], 99.95th=[  470],
     | 99.99th=[  732]
    lat (usec) : 10=0.13%, 20=0.07%, 50=0.04%, 100=0.01%, 250=96.66%
    lat (usec) : 500=3.07%, 750=0.03%, 1000=0.01%
    lat (msec) : 2=0.01%, 4=0.01%, 10=0.01%, 20=0.01%
  cpu          : usr=6.33%, sys=19.27%, ctx=1583266, majf=0, minf=104
     issued    : total=r=1572864/w=0/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
   READ: io=6144.0MB, aggrb=140824KB/s, minb=140824KB/s, maxb=140824KB/s, mint=44676msec, maxt=44676msec
  nvme0n1: ios=1568715/4, merge=0/0, ticks=178224/0, in_queue=177908, util=99.78%
@hijax_pl You need to install the rockpi4-dtbo package from the radxa apt repo to get /boot/hw_intfc.conf (and the corresponding overlay files).
update: it appears that you also need to install rockpi4b-rk-u-boot-latest and run “sudo /usr/local/sbin/rockpi4b_upgrade_bootloader.sh” then reboot to get the overlays to work.
