Hi everyone,
I’m looking for an audio HAT or codec module that works with the Radxa CM5 and supports stereo microphone input. Ideally, I’d like something with very easy driver installation—plug-and-play or minimal setup via script would be great.
I’ve used the WM8960 codec on Raspberry Pi boards before, where it’s very easy to install drivers and get stereo mic input working. Is WM8960 also supported on the Radxa CM5? If not, are there any other audio HATs or codecs you recommend that are known to work well with CM5, especially with stereo mic support?
I’d really appreciate any advice, especially from anyone who has tested audio recording on CM5.
Thanks in advance!
