Is there any update on when the Zero2 may be released?
I find it amusing that there has been a fairly well fleshed out wiki page (https://wiki.radxa.com/Zero2) for a long time but no updates as to it’s ETA.
Surely Radxa must hav some information they can share?
Same! I’ve been wanting one of these for a long time. Well technically I’ve been wanting two of them. One to put Klipper on and the other to try with my gaming handheld. I even designed it with a socketed SBC to make it easier to swap in the Zero 2 when it comes out. Of course, that was 6 months ago…
Nothing so far. We are currently busy with some other projects.
I too feel bad when Zero 2’s support is mainlined but we couldn’t release it. This is the first board I brought up in Radxa.
I can’t make any promise now since my own schedule is full. Hopefully by mid year I’ll have time to revisit Zero 2 (along with Zero) if we still haven’t already done anything to it…
Sorry if this is a stupid question but wondering if this board could be connected / used thus:
Using a single cable connecting it to a (Windows) PC which both powers the Zero 2 and enables the host computer to detect it as an Ethernet adapter (ex. using “Responder”).
Since the board has:
1 x USB 2.0 Type-C OTG & Power combo port
1 x USB 3.0 Type-C HOST
I guess the USB 2.0 offers power but the actual host connection is through USB 3.0 so I would need two cables, one to connect it to the host and one to power it?
In USB terminology, “host” is generally the device that uses the “device” device. Since you want your PC to use Zero 2 as an Ethernet, you should not connect Zero 2’s USB 3.0 Host port to your PC.
Instead, you should use the OTG port, which generally means the port can be either “host” or “device”. Since this is also the power port, you can use it like PopStick, with 1 cable providing both power and USB Ethernet connection.
So, for the time being it seems like this magnificent board will not Grace the end user correct? Just when might it? Because this seems like a wonderful piece of technology that I can’t wait to get my hands on just to be able to run source games on it because there is a decomp or rather fixed to the leak that happened in 2020 to the source engine that allows you to run games like portal, half life 2 and the sorts natively on Arm based devices. But that’s what I’d use mine for, maybe some emulation here and there but that’s what I’d use it for.
I have a project in mind that might be a bit iffy for the Radxa Zero, but the Zero2 could definitely handle. So I could not be more excited for the release if it’s not tooooo far off:D
Not with the Armbian image (have not tried it yet), I used the Armbian kernel and u-boot to build the Volumio version and noticed the speed won’t go higher than around 180-200Mbit, hald thr speed of the zero version.
Any update on when the Zero 2 will be available for sale? I know it’s already available on Allnetchina but they only have the 16gb model at the moment and the 128gb model (the one I would buy) it’s not even listed…
