My goal is emulation in SBC (Retropie or Recalbox).
Is Rock PI 4 a good option?
Doesn’t seem to work the maintainer seems to favour another.
Yes, it should work on the system, you may not get the pretty interface though. If it doesn’t you can always fall back to retroarch, which is one of the main emulator tools that both recalbox and retropie use. Your other option would be to use an android image and download the emulators that way
Tried Recalbox a few days back, GBA and CPS1 emulation were perfect, PSP games ran fine if you enable frameskip, NDS games were sluggish to unplayable, and the current rock pi image only has sound output through hdmi.
Other boards might have more support from the emulation community, but if you only need to play 8bit/16bit games then the Rock Pi 4 should be fine.
If your going to go that far just use the Atomic Pi, It’s by for the easiest and since its not arm you just install and go like any desktop pc
Atomic Pi is very large.
My intention is install a SBC inside of a PS2 Slim case.
Well that leaves you with HardKernel boards, and Raspberry Pi 3+ or lower, the Raspbeery pi 4 doesn’t have support yet. The Odroid xu4 is better and closer to the specs of the Rock Pi 4 at least with GPU.
The thing you would have to do with the Rock Pi 4 is enable multiarch support so you can use both the armhf and arm64 code to run on the system. The last time I tried to install retropie on arm64 board it was missing a frontend compiled for arm64 and was armhf only, but this might have changed
Ok.
I think the Odroid XU4 a better option.
Thank you.
The Best choice will be the Rock Pi x when it releases, in my opinion, mainly because it’s x86_64. You’ll be able to install any emulator that’s in RetroPie or Recalbox straight out and get going. No waiting for drivers or builds to be made either.
Recalbox works ok on Rock PI, except by Kodi (no HDMI sound).
It’s not a bang against the hardware just x86_64 hardware will have better support in the long run a long with better GPU’s for running the games and new emulators coming out
But this tech does work for retro gaming and does a really good job. It’s basically and upgraded XU4 with a way better CPU, with the same GPU along with being able to run the 64 bit emulators
I bought a rock 4C+ to play arcade games on.
In have downloaded the image but my Rock4C+ will not boot up. only a green led and no blue flashing. I suspect I downloaded the wrong image but am not sure this. But I do not know enough about it to know what I am doing wrong.
Can someone help me which image is the right one? Or can someone tell me what I am doing wrong? On you tube I can find very little of ROCK4C+
many thanks in advance
What version of recalbox works?
Download?
