Good evening I’m new to the community and don’t know if this question has already been asked I wanted to ask a question: is it possible to install windows 11 ARM on the RADXA 5 ITX? I saw that there is a procedure for the RADXA 5 B board… I was wondering if it was possible to use the same procedure for the 5ITX. Thank you
Not worth it right now, just use BVM by Botspot (search on github)
Thank you for your suggestion I will try to use BVM. I have already tried to use KVM with a standard windows ISO image but the result was disappointing.
hello Incognito I followed the guide you suggested but I arrived at the first boot phase where the program tells me that the architecture is not correct I attach a pdf with the screenshot produced. The operating system used is the basic radxa-debian operating system. Do you have any suggestions? Thank you
abio@rock-5-itx:~$ bvm/bvm firstboot ~/win11
█████ﭏ ﭖ█נּ וֹ█ﭡ ██◣ ◢██
█▊ ﭨ█ ﭦ█ﭐ █ﭛ ███◣ ◢███
█████ﭪ ﭖ█נּוֹ█ﭡ █▉◥█ﭩ█◤ﮋ█
█▊ ﭨ█ ﭦ█ﭐ█ﭛ █▉ ◥█◤ ﮋ█
█████ﭠ ﭖ██ﭡ █▉ ﮋ█
BOTSPOT VIRTUAL MACHINE
“Achievement unlocked: Running Windows where it absolutely should not be.”
bvm/bvm: line 812: modinfo: command not found
Installing dependencies, please wait…
Reading package lists… Done
Building dependency tree… Done
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Package installation complete!
BVM mode firstboot
◢◣ WARNING: Trying to use performance cores on your CPU only. PLEASE reach out to Bots
pot if this does not work.
Windows should install 100% automatically. This will take several hours.
qemu-system-aarch64: warning: dbind: AT-SPI: Error retrieving accessibility bus addres
s: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided b
y any .service files
arm_release_ver of this libmali is ‘g6p0-01eac0’, rk_so_ver is ‘5’.
Failed creating base context during opening of kernel driver.
Kernel module may not have been loaded
qemu-system-aarch64: egl: eglInitialize failed
qemu-system-aarch64: OpenGL is not supported by the display
QEMU did not exit successfully. Code was 1
You’re probably using a Radxa distro and you have a mismatch of the mali gpu driver with your kernel. Install armbian?
As for the screenshot, just paste the image, pdf doesn’t show up anywhere here.
You’re right, I couldn’t insert the pdf so I copied and pasted the text of what I saw on the screen in the second post I sent. I also tried with ubuntu and so it works. Windows 11 loads even if the performance is not that great. I will also try with ARMBIAN. The solution I am looking for, however, remains to start WINDOWS 11 directly, even if it seems a rather difficult path but I am willing to gain experience. I thank you for the suggestions you gave me because they allowed me to make progress. Thanks I will also try ARMBIAN.
In my experience the performance is quite awesome. You don’t really lose any performance when running a virtual machine through kvm.
Microsoft added RK3566 and RK3588 to their list of platforms so maybe they will add more drivers (huge maybe).
Personally, I have never loved the windows environment very much because I was born with Unix and the Linux environment is more congenial to me. Unfortunately, the work environment is linked to Windows, so I try to see further ahead with solutions that can represent the future. Thanks again for the tips. I will continue the research keeping as a basis what I have achieved so far.
