Hello.
On Raspberry Pi, I can play video with omxplayer (for debian buster) ou vlc (for debian bulleyes) without desktop.
Is this possible with RockPi4 B+ ?
When I tried vlc or ffplay in Ubuntu server, it says ‘gl vout display error: parent window not available’
ffmpeg are the default tools for cli processing, but not really what you want but worth a mention.
I had to think and couldn’t think of anything, Google says ‘sudo apt install mpv’ but do a search for mpv as that looks the stuff you may have to find a repo version if apt doesn’t work.
Sort of strugging how it could without at least xorg installed but something like xinit -- /usr/bin/vlc-wrapper video.mp4 should work.
Actually, you can run ffplay without Desktop with the help of SDL2 for hw acceleration.
Here i used my modified SDL2 version (source on github) and kernel 4.19.y , have a look
81.1 MB file on MEGA
Building the latest stock version of SDL2 (and Mesa) with a mainline kernel (panfrost enabled) will most likely work, but care must be taken with a special ffmpeg version for hw decoding and must match the kernel version. As they say is not a walk in the park…
ffplay can work without hw decoding but not really a nice experience with 4k or some high bit rate video.
Ok. Just for the record.
After many tests, it’s seems not possible.
- I can read and write in /dev/fb0 if X11 is not running.
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <errno.h>int main()
int fbfd = 0;
struct fb_var_screeninfo vinfo;
struct fb_fix_screeninfo finfo;
long int screensize = 0;
char *fbp = 0;
int x = 0, y = 0;
long int location = 0;// Open the file for reading and writing fbfd = open("/dev/fb0", O_RDWR); if (!fbfd) { printf("Error: cannot open framebuffer device.\n"); exit(1); } printf("The framebuffer device was opened successfully.\n"); // Get fixed screen information if (ioctl(fbfd, FBIOGET_FSCREENINFO, &finfo)) { printf("Error reading fixed information.\n"); exit(2); } // Get variable screen information if (ioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo)) { printf("Error reading variable information.\n"); exit(3); } printf("%dx%d, %dbpp\n", vinfo.xres, vinfo.yres, vinfo.bits_per_pixel ); // Figure out the size of the screen in bytes screensize = vinfo.xres * vinfo.yres * vinfo.bits_per_pixel / 8; errno = 0; // Map the device to memory fbp = (char *)mmap(0, screensize, PROT_READ | PROT_WRITE, MAP_SHARED, fbfd, 0); if ((long int) fbp == -1) { printf("Error: failed to map framebuffer device to memory.\n");perror(“Echec mmap”);
exit(4);
printf(“The framebuffer device was mapped to memory successfully.\n”);x = 100; y = 100; // Where we are going to put the pixel // Figure out where in memory to put the pixel for ( y = 100; y < 300; y++ ) for ( x = 100; x < 300; x++ ) { location = (x+vinfo.xoffset) * (vinfo.bits_per_pixel/8) + (y+vinfo.yoffset) * finfo.line_length; if ( vinfo.bits_per_pixel == 32 ) { *(fbp + location) = 100; // Some blue *(fbp + location + 1) = 15+(x-100)/2; // A little green *(fbp + location + 2) = 200-(y-100)/5; // A lot of red *(fbp + location + 3) = 0; // No transparency } else { //assume 16bpp int b = 10; int g = (x-100)/6; // A little green int r = 31-(y-100)/16; // A lot of red unsigned short int t = r<<11 | g << 5 | b; *((unsigned short int*)(fbp + location)) = t; } } munmap(fbp, screensize); close(fbfd); return 0;}
- If X11 is running, I cannot write in /dev/fb0, but II can use DRM layer. See for example docs/drm-howto/modeset.c at master · dvdhrm/docs · GitHub
- I can use VLC + devilspi2 to display video without decoration under X11
