I am new to device tree and therefore would like to ask help with i2c enabling. I use my own build of Android based on Radxa sources and would like to turn on i2c on pin 3 and 5.
As far as I understand pin 3 and 5 are i2c7m3, but by default i2c7m0 is enabled and used for audio chip.
Is possible to mux the same I2C Bus to multiple pins - so instead of:
i2c7: i2c@fec90000 {
compatible = "rockchip,rk3588-i2c", "rockchip,rk3399-i2c";
pinctrl-0 = <&i2c7m0_xfer>;
i2c7 {
/omit-if-no-ref/
i2c7m0_xfer: i2c7m0-xfer {
rockchip,pins =
/* i2c7_scl_m0 */
<1 RK_PD0 9 &pcfg_pull_none_smt>,
/* i2c7_sda_m0 */
<1 RK_PD1 9 &pcfg_pull_none_smt>;
I can do like:
pinctrl-0 = <&i2c7m0m3_xfer>;
i2c7 {
/omit-if-no-ref/
i2c7m0m3_xfer: i2c7m0m3-xfer {
rockchip,pins =
/* i2c7_scl_m0 */
/* i2c7_sda_m0 */
/* i2c7_scl_m3 */
<4 RK_PB2 9 &pcfg_pull_none_smt>,
/* i2c7_sda_m3 */
<4 RK_PB3 9 &pcfg_pull_none_smt>;
Is it correct?
