I have some questions caused by the lack of documentation about the wifi module.
Hopefully you guys can help me.
- The Wifi module has two antenna plugs labeled 1 and 2. The wifi module comes with two antennas labeled WIFI6-L-V02 and WIFI6-R-V01. As they have different lengths I would assume one is for 2.4 GHz and one for 5 GHz. I couldn’t find any information which plug on the wifi module is used for which frequency or if it doesn’t matter.
- The open antenna end is on a 3M sticky paper. Where do you guys glue it on the Rock5 or are you routing it outside of a case (if non metal) and into an antenna plastic dummy?
- As I’m using the original radxa metal case I have to put the antennas outside. But why has the original case no holes foreseen for this? Makes no sense to keep the antennas inside of a metal case.
Thanks!
