Installing stable 6.1 debs from up-to-date bsp on Pi S - out of memory?
Hi, I am trying to install radxa kernel 6.1 to test RockPi S + CS42448 I2S/I2C DAC setup . With a few-months older bsp I could compile latest-kernel 6.6 debs and dpkg -i install them on my 512MB Pi S with the default 200MB compressed-RAM swap. Today I:
  • updated bsp from github, compiled stable with:
./bsp --no-build -n linux stable
  • checked the .src/linux dir, then
./bsp --no-prepare-source -n linux stable
  • copied the common and pi-s-specific debs to my Pi-S
  • and tried to install with:
sudo dpkg -i *6.1*deb
Unlike in my previous installations of 6.6 debs built with the previous bsp, this installation tries to update overlays:
update-initramfs: Generating /boot/initrd.img-6.1.68-1-stable
Updating overlays for 6.1.68-1-stable ...
The “updating overlays” process runs python3 which consumes all RAM including the 200MB swap ramdisk. I added 1GB of swap to a swap file on the slow SD card. The “updating overlays” takes 650MB of swap space, dragging the board to halt due to the slow swap space.
Please is there a way to fix that, so that kernel stable debs compiled with radxa bsp can be installed on the 512MB Pi S?
Thank a lot,
Pavel.
Hm, I had to remove /etc/kernel/postinst.d/yz-update-overlays config, installed by the rsetup package.
I’m facing this same problem. Did removing the yz-update-overlays config have any side effects?
TBH I do not remember the details, but I did not have any issues after removing that file. Check contents of the yz-update-overlays file what it actually does, it should be easy to see. I do not have the file available for now.
I could not find it on github, the radxa build system is very complicated, many repositories.
