Install Windows 11 on X4
Hi All,
I had installed the windows 11 LTSC on X4 successfully,
But when I install these driver below, the output of screen become abnormal, and system crushed.
1. https://dl.radxa.com/x/x4/Intel_Chipset_Driver.zip
2. https://dl.radxa.com/x/x4/Intel_Graphics_driver.zip
After that, I reinstall the OS again, it is normal initially, because I do not install any driver above this time, but after I did windows update (It installed Intel Display Driver by Windows Update), the the output of screen become abnormal again.
Can any one could solved this issue ?
BTW, I saw the CPU clock is 800MHz in the windows system information, the hardware specification noted “Max Turbo Frequency: 3.40 GHz”, is there anyone knows why the CPU clock is different ?
Thanks
We verified X4 with WIN11 LTSC without problem, this one looks like hardware issue.
You can contact the store customer service for after-sales service
The Windows system information does not display the real-time frequency. You can view the real-time frequency in Windows Performance Monitor.
