How to install the system on EMMC using DD command in rock 3A?
use this command dd if=rock-3a-ubuntu-focal-server-arm64-20220829-0843-gpt.img of=/dev/mmcblk0p1 bs=1M, is not work start.
How to use DD to install the system?
dd to mmcblk0 instead of mmcblk0p1 because this is a full disk image
dd bs=1M if=/home/rock/rock-3a-ubuntu-focal-server-arm64-20220701-0200-gpt.img of=/dev/mmcblk0
/dev/mmcblk0 is emmc .
poweroff ,Unplug the SD card and power on, only the green light is always on.
拔电源,SD卡插电开机只有绿灯常亮,系统好像没启动
Try using a USB flash drive as the source of the image. The source and destination of the dd are the same locations, so the file may have been modified during execution.
