This print log
SoftReset, 27933961 us
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
Manufacturer ID:0xff
CH0 RX Vref:27.7%, TX Vref:19.8%,0.0%
CH1 RX Vref:28.7%, TX Vref:21.8%,0.0%
CH2 RX Vref:27.7%, TX Vref:20.8%,0.0%
CH3 RX Vref:28.7%, TX Vref:20.8%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-g77a5f377ab-230203-dirty #heng (Feb 28 2023 - 14:22:53)
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
spl: partition error
Trying fit image at 0x4000 sector
Verified-boot: 0
Checking atf-1 0x00040000 … sha256(bb1bbbc832…) + OK
Checking uboot 0x00200000 … sha256(c8acd879c4…) + OK
Checking fdt 0x0031a280 … sha256(1245389642…) + OK
Checking atf-2 0x000f0000 … sha256(30812190d0…) + OK
Checking atf-3 0xff100000 … sha256(cb7bdbec2b…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 513.159 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-499-ge63a16361:derrick.huang
NOTICE: BL31: Built : 10:58:38, Jan 10 2023
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for O PTEE will return SMC_UNK
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-g77a5f377ab-230203-dirty #heng (Feb 28 2023 - 14:22:53 +0800)
Model: Radxa ROCK 5B
PreSerial: 2, raw, 0xfeb50000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: eda43000
Relocation fdt: eb9f9f58 - eb9fecd8
CR: M/C/I
Using default environment
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
Unknown partition table type 0
PartType:
DM: v2
No misc partition
boot mode: normal
FIT: No boot partition
No resource partition
Failed to load DTB, ret=-19
No find valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 24000 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 24000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 750000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: No ethernet found.
Hit key to stop autoboot(‘CTRL+C’): 0
pcie@fe150000: PCIe Linking… LTSSM is 0x0
pcie@fe150000: PCIe Linking… LTSSM is 0x1
pcie@fe150000: PCIe-0 Link Fail
Device 0: unknown device
switch to partitions #0, OK
mmc0(part 0) is current device
** No partition table - mmc 0 **
Device 2: SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Vendor: 0x2207 Rev: V1.00 Prod: sfc_nor
Type: Hard Disk
Capacity: 16.0 MB = 0.0 GB (32768 x 512)
… is now current device
GUID Partition Table Header signature is wrong: 0xFFFFFFFFFFFFFFFF != 0x5452415020494645
GUID Partition Table Header signature is wrong: 0xFFF Header signature is wrong: 0xFFFFFFFFFFFFFFFF != 0x5452415 020494645
** No partition table - mtd 2 **
Device 1:
starting USB…
No working controllers found
USB is stopped. Please issue ‘usb start’ first.
starting USB…
pcie@fe150000: failed to find reset-gpios property
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB…
No ethernet found.
Could not get mtd 0
Booting FIT Image FIT: No boot partition
FIT: No fit blob
FIT: No FIT image
Unknown command ‘bootrkp’ - try ‘help’
