Inquiry about X4 Support for Windows and FPS Performance on Dual 1920x1080 Displays
I am currently developing a game machine and am using an X2L board. While running Windows as the operating system, I’ve noticed that when using dual 1920x1080 displays, the X2L is able to achieve a frame rate of up to 30 FPS. However, for my application, I require a stable frame rate of 60 FPS across both displays.
I would like to inquire about the following:
  1. Does the X4 board support Windows as an operating system?
  2. What is the maximum FPS that can be achieved on dual 1920x1080 displays using the X4 board?
Your assistance with these questions would be greatly appreciated, as I’m looking to improve the performance of my game machine.
Thank you in advance for your time and support.
Hello
  1. X4 support windows
  2. X4 2xHDMI support 4K both, for the FPS, it’s depend the use case, what’s your use case?
Thanks for your message.
The current game uses OpenGL (QT/C++) and draws one screen (19201080) at 12fps and the other screen (19201080) at (60fps).
I’m currently using X2L but the fps is not guaranteed.
So I’m trying to use the X4 series but I couldn’t find anything that supports Windows on https://radxa.com/products/x/x4.
X4 can support this fps?
And can you let me know GPU size of X4?
Hi, X4 is support windows, we will complete the info on website.
we do not have accurate fps for your use case, but below is GPU specifications for X2L(J4125) vs X4(N100). FYI
https://www.intel.com/content/www/us/en/products/compare.html?productIds=231803,197305
depends on what ur running it ran good
https://www.youtube.com/watch?v=uiYRR7ERvmA&t=354s
