I would like to ask about the proper procedure for kernel build and firmware update on the A733 platform.
Currently, I am booting the system using the radxa-a733_bullseye_kde_r2.output_512.img image via SD card.
I cloned the kernel source from:
https://github.com/radxa-pkg/linux-a733.git
(using --recurse-submodules)
The repository states are:
src: (HEAD detached at e41499895c17) [linux-6.1-stan-rkr5.1]
device-a733: origin/device-a733-v1.4.8
bsp: origin/cubie-aiot-v1.4.8
I built the kernel using make deb.
After building, I transferred the generated .deb packages to the target board using scp:
linux-headers-5.15.147-18-a733_5.15.147-18_arm64.deb
linux-image-5.15.147-18-a733_5.15.147-18_arm64.deb
linux-libc-dev_5.15.147-18_arm64.deb
linux-headers-radxa-cubie-a7s_5.15.147-18_all.deb
linux-image-radxa-cubie-a7s_5.15.147-18_all.deb
linux-libc-dev-radxa-cubie-a7s_5.15.147-18_all.deb
linux-headers-radxa-a733_5.15.147-18_all.deb
linux-image-radxa-a733_5.15.147-18_all.deb
linux-libc-dev-radxa-a733_5.15.147-18_all.deb
Then I installed them with:
sudo dpkg -i linux-libc-dev_5.15.147-18_arm64.deb
sudo dpkg -i linux-headers-5.15.147-18-a733_5.15.147-18_arm64.deb
sudo dpkg -i linux-image-5.15.147-18-a733_5.15.147-18_arm64.deb
sudo dpkg -i linux-headers-radxa-cubie-a7s_5.15.147-18_all.deb
sudo dpkg -i linux-image-radxa-cubie-a7s_5.15.147-18_all.deb
However, after rebooting, the system boots with the A7S kernel instead of the A7A kernel, which causes boot errors.
Could you please advise:
What is the correct method to build the kernel for A7S?
Which packages should be installed?
What is the proper procedure to update the kernel/firmware on this platform?
Thank you for your support.
