Hello All,
I have connected the imx219 sensor on the camera connector, kernel module imx219 is enabled however it is failing. I tried to detect the camera with i2cdetect on bus 4, I could see the slave address 0x64. After digging around I found the camera sensor address is 0x10, which is not showing here, whereas as0x64 is crypto IC. is there any way around from where I can make the camera work with kernel 5.11.
Thanks
