ynjiun
April 2, 2021, 2:15am
1
After I installed rknn toolkit successfully on my PC (ubuntu 18.04 LTS), try to import rknn.api the following error message shows up:
ImportError: rk3399pro/lib/python3.5/site-packages/rknn/api/rknn_base.cpython-35m-x86_64-linux-gnu.so: undefined symbol: PyFPE_jbuf
Follow recommendations from RKNN toolkit trouble shooting s and still doesn’t work.
Found the reasons why here , but no clue how to fix it.
Anybody has the same issue? Please help. Thanks a lot.
ynjiun
April 2, 2021, 6:42pm
2
after a long hours of investigation, it turns out the python3.5 I installed without fpectl turn on
So the solution is a little bit involved but works: I need to reconfigure/recompile the python3.5 --with-fpectl enabled, the following are the step by step process works on my machine:
cd /usr/src
sudo wget https://www.python.org/ftp/python/3.5.9/Python-3.5.9.tgz
cd Python-3.5.9
sudo ./configure --enable-optimizations --with-fpectl
sudo make altinstall
then reinstall rknn toolkit using the newly compiled/installed python3.5
P.S. python3.5 is old and not supported anymore, I wish rknn toolkit can support python3.6 or later soon… ; ))
