[Image] Rock Pi S v1.1 Slarm64 (aarch64 unofficial slackware)
update kernel 5.13.7
slarm64-current-aarch64-server-rock_pi_s-5.13.7-build-20210731.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.13.7-build-20210731.img.zst.sha256
kernel 5.14.1
slarm64-current-aarch64-server-rock_pi_s-5.14.1-build-20210907.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.14.1-build-20210907.img.zst.sha256
I need kernel source code of this version 5.9.12 that is working for Rock-PI-S because my USB-WiFi driver only compiles for this kernel version, NOT the (5.14.1) one you posted
The image for this link is taken offline.
Can you please put it back? Or just give me link to the kernel source (5.9.12) for this image?
Thanks
kernel 5.9.12 is the kernel from kernel.org with additional patches. at the moment everything is switched to 5.14.y, you can just switch the branch from 5.14.y to 5.9.y and try to build. you can also try to raise your driver for building on kernel 5.14.y
Do you have a list of patches that applied in 5.9.12, particularly for Rock Pi S?
prefixed patches board-rockpis-
update kernel 5.15.2
slarm64-current-aarch64-server-rock_pi_s-5.15.2-build-20211118.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.15.2-build-20211118.img.zst.sha256
Very impressive. Thanks for keeping working on it.
update kernel 5.16.9
installation README.TXT
slarm64-current-aarch64-server-rock_pi_e-5.16.9-build-20220214.img.zst
slarm64-current-aarch64-server-rock_pi_e-5.16.9-build-20220214.img.zst.sha256
update kernel 4.4.302
slarm64-current-aarch64-server-rock_pi_s-4.4.302-build-20220223.img.zst
slarm64-current-aarch64-server-rock_pi_s-4.4.302-build-20220223.img.zst.sha256
kernel 5.17.2
slarm64-current-aarch64-server-rock_pi_s-5.17.2-build-20220410.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.17.2-build-20220410.img.zst.sha256
kernel 5.18.3
slarm64-current-aarch64-server-rock_pi_s-5.18.3-build-20220611.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.18.3-build-20220611.img.zst.sha256
kernel 5.19.0
slarm64-current-aarch64-server-rock_pi_s-5.19.0-build-20220805.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.19.0-build-20220805.img.zst.sha256
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
2639 bytes read in 5 ms (514.6 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
200 bytes read in 4 ms (48.8 KiB/s)
54420 bytes read in 11 ms (4.7 MiB/s)
30007808 bytes read in 1274 ms (22.5 MiB/s)
libfdt fdt_getprop(): FDT_ERR_NOTFOUND
313 bytes read in 8 ms (38.1 KiB/s)
Applying kernel provided DT overlay rockchip-rk3308-opp-1.2ghz.dtbo
313 bytes read in 9 ms (33.2 KiB/s)
Applying kernel provided DT overlay rockchip-rk3308-opp-1.3ghz.dtbo
2698 bytes read in 9 ms (292 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
9599587 bytes read in 414 ms (22.1 MiB/s)
Moving Image from 0x680000 to 0x800000, end=2540000
## Loading init Ramdisk from Legacy Image at 04000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    9599523 Bytes = 9.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02800000
   Booting using the fdt blob at 0x2800000
   Loading Ramdisk to 1d5fb000, end 1df22a23 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0)
   Loading Device Tree to 000000001d585000, end 000000001d5fafff ... OK
Starting kernel ...
[   21.896288] rockchip-pinctrl pinctrl: pin gpio1-22 already requested by ff0c0000.serial; cannot claim for ff140000.spi
[   21.909260] rockchip-pinctrl pinctrl: pin-54 (ff140000.spi) status -22
[   21.918285] rockchip-pinctrl pinctrl: could not request pin 54 (gpio1-22) from group spi2-miso  on device rockchip-pinctrl
[   21.933498] rockchip-spi ff140000.spi: Error applying setting, reverse things back
[   22.201340] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[   22.213236] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[   22.222590] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[   22.231901] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
if you want to transfer the system to SDcard to internal memory (eMMC or NAND),
follow transfer-to-disk
slarm64 GNU/Linux (ttyS2)
Kernel 5.19.0 (aarch64)
rock-pi-s login:
kernel 5.19.2
slarm64-current-aarch64-server-rock_pi_s-5.19.2-build-20220820.img.zst
slarm64-current-aarch64-server-rock_pi_s-5.19.2-build-20220820.img.zst.sha256
kernel 6.0.0
slarm64-current-aarch64-server-rock_pi_s-6.0.0-build-20221010.img.zst
slarm64-current-aarch64-server-rock_pi_s-6.0.0-build-20221010.img.zst.sha256
kernel 6.0.8
slarm64-current-aarch64-server-rock_pi_s-6.0.8-build-20221114.img.zst
slarm64-current-aarch64-server-rock_pi_s-6.0.8-build-20221114.img.zst.sha256
kernel 6.1.1
slarm64-current-aarch64-server-rock_pi_s-6.1.1-build-20221227.img.zst
slarm64-current-aarch64-server-rock_pi_s-6.1.1-build-20221227.img.zst.sha256
kernel 6.2.2
slarm64-current-aarch64-core-rock_pi_s-6.2.2-build-20230306.img.zst
slarm64-current-aarch64-core-rock_pi_s-6.2.2-build-20230306.img.zst.sha256
slarm64-current-aarch64-server-rock_pi_s-6.2.2-build-20230306.img.zst
slarm64-current-aarch64-server-rock_pi_s-6.2.2-build-20230306.img.zst.sha256
kernel 6.4.10
slarm64-current-aarch64-core-rock_pi_s-6.4.10-build-20230812.img.zst
slarm64-current-aarch64-core-rock_pi_s-6.4.10-build-20230812.img.zst.sha256
slarm64-current-aarch64-server-rock_pi_s-6.4.10-build-20230812.img.zst
slarm64-current-aarch64-server-rock_pi_s-6.4.10-build-20230812.img.zst.sha256
kernel 6.5.7
slarm64-current-aarch64-core-rock_pi_s-6.5.7-build-20231014.img.zst
slarm64-current-aarch64-core-rock_pi_s-6.5.7-build-20231014.img.zst.sha256
slarm64-current-aarch64-server-rock_pi_s-6.5.7-build-20231014.img.zst
slarm64-current-aarch64-server-rock_pi_s-6.5.7-build-20231014.img.zst.sha256
