Hi, please is my analysis of I2S peripherals on the CM5-IO board correct (based on schematics in Index of /cm5 )? IIIUC there is no SDO0 for external connection available:
I2S0: lines go only to the codec ES8316, not available on the 40pin connector or some other pinheader.
I2S1: only inputs and SDO1 are available, no SDO0
The SDO0 pin is used as I2C CLK for RTC (non-critical) and USB-C (critical).
If it’s correct, I wonder if SDO1 can be enabled without enabling SDO0 (i.e. without disrupting the board setup).
I could desolder the codec but QFP 0.4mm pitch would be quite difficult to connect wires to.
Thanks a lot for confirmation or some suggestion.
Pavel.
