“I wanted to share my work: Linux Q83 on Orion O6” “Sharing my project: Linux Q83 on Orion O6”
I would like to share my recent project: running Linux Q83 on the Orion O6 platform .
The main goal of this work was to test the compatibility, performance, and stability of Linux Q83 on Orion O6 hardware. I focused on system installation, configuration, and optimization for this environment.
Key points of the project:
  • Successful installation of Linux Q83 on Orion O6
  • Hardware compatibility testing (CPU, GPU, peripherals)
  • System performance measurements
  • Bug fixes and improvements
This project may be useful for anyone interested in experimenting with Linux on less common platforms or exploring Orion O6 hardware capabilities.
does the npu/gpu work, can we run ollama on gpu on it ?
The underlying dependency of ollama is llama.cpp.
Therefore, if you need to use GPU inference for LLM, it is recommended to use the combination of llama.cpp and GPU acceleration: enable -DGGML_VULKAN=ON, compile llama.cpp, and obtain the “c++ API for opening vulkan configuration: llama-cli”.
Use this llama-cli for GPU inference on Orion O6.
Note that there’s already one thread on this topic (Does Vulkan work?) where several of us found that while it works it does not improve anything.
guess its time to test a gpt-oss gguf with ollama
ollama pull hf.co/unsloth/gpt-oss-20b-GGUF:Q8_0
